Cluster Light..help. - 3000GT/Stealth International Message Center
Old 07-16-2008, 12:10 PM   #1 (permalink)
sl3kgt's Avatar
Drives: 94 SL/91 300ZX TT
sl3kgt is an unknown quantity at this point
Feedback Score: 2 reviews
Exclamation Cluster Light..help.
Ok so yesterday while driving I saw that 3 lights came on..
1) brake light - probably low on brake fluid?
2) Battery - taking the alternator out now..lets see
3) a light thats at the bottom..on the right side corner..cant tell what its for..so please if someone could tell me as I dont have the owners manual..
edit: STEALTH REMANUFACTURED INSTRUMENT CLUSTER EXCHANGE
on that site is the cluster..so the light that im not sure of is the 1 right at the corner (rite side) at the bottom.
sl3kgt is offline   Reply With Quote
Old 07-16-2008, 12:13 PM   #2 (permalink)
Super Duper Mod
lawdogg's Avatar
Drives: at half throttle
lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2
Feedback Score: 93 reviews
Default Re: Cluster Light..help.
Are they fully on or like dimly on?
If they are on, but dim, it sounds like a common symptom of an alternator that's going bad.
Old 07-16-2008, 12:25 PM   #3 (permalink)
sl3kgt's Avatar
ah ok thanks.
im trying to open the alternator..is there a DIY on it? id appreciate your help..
Old 07-16-2008, 12:30 PM   #4 (permalink)
Super Duper Mod
lawdogg's Avatar
Stealth 316 - Alternator removal
Stealth 316 - Alternator Drive Belt
Stealth 316 - Alternator Rebuild 1991-1995 3S DOHC
Hope that helps!
Old 07-16-2008, 12:37 PM   #5 (permalink)
sl3kgt's Avatar
thanks alot! gonna try and remove it now.
Old 07-16-2008, 03:16 PM   #6 (permalink)
3/S enthusiast
andyvr4's Avatar
Drives: 91 VR-4, 99 Zx2
andyvr4 is an unknown quantity at this point
Feedback Score: 1 reviews
You can figure out what each of the lights stand for using the following information.
Left
1. Door-ajar warning light
2. Oil pressure warning light
3. Check engine warning light
4. Tour or Sport for the ECS
5. Security indicator
Center Warning Lights
1st space down
Left: 4-wheel steering oil level warning light
Right: Brake warning light
2nd space down:
Left: Anti-lock brake warning light
Right: Active Exhaust Tour indicator
3rd space down
Left: cruise control indicator
Right: cruise control ON indicator
4th space down:
Left: charging system warning light
Right: High-beam indicator
Right Warning Lights
1st down: Not used
2nd down: Seatbelt warning light
3rd down: Washer fluid (2 storage containers)
4th down: Supplemental restraint system (SRS) warning light
5th down:
Left: Active Aero system warning light
Right: Engine coolant level warning light
If you live in the Delaware, Maryland, or Virginia area check out our 3si chapter forum
andyvr4 is offline   Reply With Quote
