#1 (permalink) |
OK I have a 95 3000, non turbo, I just rebuilt the engine, and now when I try to turn it over it just keeps cranking but wont start. I have done every test imagainable on it and every tech. I have look at it is stumped. The car has fuel, spark, compression, and the timing is dead on. The scanner shows up with I take something apart, but otherwise it show no communication. Which I assume means nothings wrong. The only thing ab normal would be the injector pulse is a little off, but I pulled the fuel pump relay and tried the propane, starter fluid method and got no results. If I could get any help from you guys or info I would be very thankful.
Thanks Chris |
#2 (permalink) | |||||||
More Than Meets the Eye
All I can think of is to check the ECU's fuse.
#4 (permalink) |
Ive talked to another technician and he says there's a good chance its the ecu. Now does anyone know if the ecu was bad would that keep the car from starting, and could it go bad without blowing the fuse. What causes the ecu to go bad??
Any help would be appriciated. thanks chris |
