Old 03-26-2008, 05:51 PM   #1 (permalink)
scenie is an unknown quantity at this point
Default Car Issues
I have a couple of questions. My mechanic said he can hear my timing belt "flapping" meaning I need to replace it asap. Im at 60k miles exactly. Hopefuly no engine damage has been caused. Secondly he looked at my brake pads and said they were fine, yet I get a horrible squeling whenever I brake. Rotors shot maybe? Last question is I hear this almost thumping thudding noise when im driving, seems to be coming from a tire or wheel. The tires are new and pads are fine, only thing I can figure is something wrong with the shocks. Any insight, opinions or help would be appreciated. I got a quote on the timing belt and water pump together for 800 bucks, this includes a couple other new belts and ima have him look at the tensioner and pully as well.
scenie is offline   Reply With Quote
Old 03-26-2008, 06:02 PM   #2 (permalink)
Drives: 1993 Mits 3000gt VR4
q2418130103p is an unknown quantity at this point
Default Re: Car Issues
regardless of what your mechanic hears, you need to have the timing belt changed. if/when it snaps the damage it will cause will far out weight the 800 to replace it now. the auto tensioner should be replaced at the same time (youll get lots of input on this one from board members real soon....)
if the pads are fine, the wear sensor might be alittle bent, causing it to prematurly squeak.
the thumping noise, what speed, what rpm, accelerating, decelerating, cruising.
Want to Buy:
  • Door Interior with no bubbles
q2418130103p is offline   Reply With Quote
Old 03-26-2008, 06:09 PM   #3 (permalink)
"the thumping noise, what speed, what rpm, accelerating, decelerating, cruising"
It only seems noticable at slower speeds like 5-10mph, though I couldn't be sure because the exhaust gets kinda loud when beyond that.
Old 03-26-2008, 06:11 PM   #4 (permalink)
how frequent is it? once per wheel revolution, once per engine rev?
i have not clue what it is, i just imagine this info oculd help someone else figure it out.
Old 03-26-2008, 06:12 PM   #5 (permalink)
Has too many spare parts
Intropy's Avatar
Drives: 2nd Gen RT/TTs
Intropy Level 1Intropy Level 1
Does it go away if you apply the brakes? Not uncommon to have a pad thumping around, may need a shim.
Intropy is offline   Reply With Quote
Old 03-26-2008, 06:20 PM   #6 (permalink)
No it still does it when I apply the brakes. it is however more noticable when i go over a bump. It basically sounds like something rattling around, its very hard to explain. I removed everything from ym trunk, spare tire and all to eliminate those possibilities but it somehow seems suspension or drivetrain related. Im just clueless as well, it may not even be anything critical it just bugs me I can't figure out exactly where its coming from and what it is lol
