#1 (permalink) |
Wrks on car btwn classes
my car hesitates at low throttle just cruising. It doesnt when i get on it. I didnt find any boosts leaks. Tuning is good. It doesnt do it when i am at wot. What could it be?
Also my oil cap leaks really bad. Could that be the problem? I replaced the oil cap with a OReillys one so i think thats fixed. Although i think it still leaks. Maybe it just the old oil that spilled before. |
#2 (permalink) |
DSM GURU
I have this problem to, still cant figure it out
1992 Mitsubishi 3000GT VR-4 RIP 3/06
1990 Eagle Talon TSI AWD - 11.29@126 - SOLD 1991 Dodge Stealth RT/TT - Traded 1992 Eagle Talon TSI AWD - Where fast really is cheap |
#3 (permalink) |
Oh SNAP!!!
well i would pressure test it for starters....what kind of condition are your plug wires/spark plugs in? check your ECU for any fried caps on it..which is common for the early years...clean your Mass air flow sensor..with the right spray..
If you feel I have answered your question..leave me some rep...thanks
**1ST place RMG 07 best engine** Like the snake the BITE must be felt and not seen, goin super, until then super slow want some!!! 1st car with the Enkei RZ-5 18''x8.5'' *534x306* ![]() 1994 Dodge Stealth R/T TT~Pearl Yellow |
#4 (permalink) | |
DSM GURU
New MSD OEM Boot Style Wires and Copper NGK's @.30 Tryed 2 ECU's, both have good caps Cleaned Mas and changed it with a spare, no change ![]() |
#6 (permalink) | |
DSM GURU
Mysterious Lean Spikes and Hesitation |
#7 (permalink) |
Wrench Pimp
bro I have the same problem, This car has done it since i owned it. Even after engine rebuild. Pressure tested the crap out of it many times, fixed TINY leaks, now there is none, it holds 15 psi for minutes before dropping. I have new plug wires, plugs, fuel filter and pump. Its annoying as hell. Even in neutral the engine misses while giving it the slightest throttle . I have tested electrical sensors. One thing that clears it up tho, if I run the CAR with NA intake piping, no hesitation. hmmm
