car cranks but will not stay running, any suggestions? - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 07-25-2002, 09:52 PM   #1 (permalink)
STEALTHAWDTT's Avatar
STEALTHAWDTT is an unknown quantity at this point
Feedback Score: 0 reviews
Question car cranks but will not stay running, any suggestions?
I was just riding around town the other day and nailed it in 2nd gear and my car just jerked like a fuel cut of some sorts and shortly after died. I pulled over cranked car back up and it was fine. But once i got ready to pull in driveway it just died, and would not crank back up even giving it gas. I just ran the other night at track with 110 race gas 50/50 with 93 with mbc set at 16psi, no other mods. Now car still will not stay running, crank no prob, but soon as it cranks, even giving it gas, rpms just drop car dies and instrument lights come on. Ive heard it could be ecu, coil pack, vaccuum hose, or combination. Any suggestions are greatly appreciated, need car running again.
Thanks
Brian
1992 Stealth R/T TT
MBC
Turbo XS RFL
13.20 @ 105.6
STEALTHAWDTT is offline   Reply With Quote Quick reply to this message
Old 07-25-2002, 10:41 PM   #2 (permalink)
Baka! Baka! Baka! Baka!
Ryououki's Avatar
Drives: MB SLK32 ///AMG
Ryououki is an unknown quantity at this point
Feedback Score: 2 reviews
Default
Sounds like a fuel delivery problem to me.
I'd check the vaccuum hoses going to the fuel regulator.
Check the accelerator cable under the hood at the throttle body.
Then check the wiring harness above the fuel pump in the trunk area.
Then check the fuel filter to see if there are any leaks
After that, I'd probably say it's a fuel pump problem.
But I could be wrong, but it's still what I'd do.
Ryououki is offline   Reply With Quote Quick reply to this message
Old 07-25-2002, 11:21 PM   #3 (permalink)
OMGOMGOMGOMG
J-Ville VR-4's Avatar
Drives: 91 VR-4
J-Ville VR-4 is an unknown quantity at this point
Feedback Score: 13 reviews
Default
Seems like a fuel pump problem, most likely the wiring.
Jake - 91 VR-4
J-Ville VR-4 is offline   Reply With Quote Quick reply to this message
Old 07-31-2002, 05:25 PM   #4 (permalink)
Default any more suggestions
still looking for an answer to problem, going to try datalogger tonight and see if any sensors are dead. Also going to try ecu in friends R/T and see if car does same thing. Thanks.
Old 07-31-2002, 07:53 PM   #5 (permalink)
racing is war
Drives: 92 Eagle Talon TSI A
Paylay is an unknown quantity at this point
Feedback Score: 1 reviews
Default
Brian you stole my screen name from every other board and even my email try to fix it when you are still stuck, Matt and myself will come show you what it is Its the ECU I am 98.734564397% sure same thing happened to mine like said. CAll my house 796-1023 and we make plans to check your ecu
1033hp/658tq 49 psi
1069hp/667tq 45psi 50 shot
Wier's Automotive Racing
Magnus Motorsports
ECMLink
Shearer Fabrications
National Speed Inc
Fuel Injector Clinic
ForcedFour
Paylay is offline   Reply With Quote Quick reply to this message
Old 08-01-2002, 12:45 PM   #6 (permalink)
ph33r m1 b33r
Kid Death is an unknown quantity at this point
Default
Look at all your turbo piping...
Your engine's getting the fuel cause it will idle, but once you start to boost, it makes it run rich since one of the turbo hoses isn't connecting and it isn't getting all the registered air...
So look around at ALL the hoses and pipes from both turbo's...
1993 Mitsubishi 3000gt VR-4 Wrecked and gone
1993 Mitsubishi 3000gt VR-4 almost bought and on the way
Kid Death is offline   Reply With Quote Quick reply to this message
Old 08-03-2002, 04:28 PM   #7 (permalink)
Hail to the King, Baby
dabigv13's Avatar
dabigv13 is an unknown quantity at this point
Default
I had the exact same problem.
http://www.3si.org/vbb/showthread.php?threadid=91367
Mine turned out to be that the large honeycomb in my MAF sensor came undone and caused a huge air restriction. Take a peek inside your MAF and see what it is. Other things that could be the culprit would be fuel filter or fuel pump.
Your 1995 Mitsubishi 3000GT SL is one of 4245. It was built in 1st week of 07/94 and it was the 1421st post production car of that model to come out of the plant. There were 5395 other cars of the model year made at the Nayoga plant before your car.
There are 45 other cars that were made with both the same interior and exterior color. There are 85 cars with the same exterior color and 1115 cars with the same interior color.
Other Numbers
Exactly Identical (*) 5
dabigv13 is offline   Reply With Quote Quick reply to this message
Old 08-16-2002, 08:40 PM   #8 (permalink)
kav
kav's Avatar
Drives: GTO,GTR, supra
kav is an unknown quantity at this point
Feedback Score: 4 reviews
Default
I had the same sort of problem,like kid death said check all your tubo piping,maybe one of the clips have loosened & the pipe has come off.Goodluck.
kav is offline   Reply With Quote Quick reply to this message
Old 08-17-2002, 10:29 AM   #9 (permalink)
Default UPDATE ON PROBLEMS
Well, Ive changed the fuel filter, checked all i/c pipes, pulled ecu and no sign of leaky caps. After a week of fooling with it, it only acts up in the morning when theres a lot of moisture on the car, under the hood. I've driven the car every day now after work, 6-8 pm, without any problems what so ever. But every morning, crank it up, runs for about 20 secs, dies.
Old 08-17-2002, 02:46 PM   #10 (permalink)
ManyToys is an unknown quantity at this point
Default
Crank and cam sensors......cause a crank but no start problem too.......my friends had some problems with various cars that that was the thing causing it.........check those two sensors out
Chris
aka Manytoys
97 Nissan 200SX SE-R
94 Dodge Stealth R/T
90 Plymouth Laser RS
87 Chrysler 5th Ave
76 Dodge Power Wagon
ManyToys is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
