Old 08-18-2006, 11:17 PM   #1 (permalink)
Stealth Pilot
virtualarson's Avatar
Drives: 91 Dodge Stealth ES
virtualarson Level 1virtualarson Level 1
Unhappy Car Boggs Out When Pedal Is Smashed.
Okay, when I floor it, or any high rpm action at all, the car jerks as if it was stalling. It is NOT my clutch, my clutch is perfect, I just can't think of anything else.
It's been to Dodge 2wce this week, and now it's doing this s***, they refuse to look at it for free.
Stealth Pilot
Originally Posted by Struggly
And what the hell is a "dawg"? Do we look like shizzleous assholes to you?
virtualarson is offline   Reply With Quote
Old 08-18-2006, 11:32 PM   #2 (permalink)
Watch this.
Red92vr4's Avatar
Drives: '94 Stealth TT
Red92vr4 Level 1Red92vr4 Level 1
Default Re: Car Boggs Out When Pedal Is Smashed.
Plugs and wires maybe? I have had this problem before, and that usually fixes it if said items are old. Either that or a coil pack(s) went bad.
Red92vr4 is offline   Reply With Quote
Old 08-18-2006, 11:45 PM   #3 (permalink)
Andr3w's Avatar
Drives: 1994 3000GT VR-4
Andr3w is an unknown quantity at this point
i too recently had this problem when i would go in wot. changed out the sparkplugs and the problem was fixed. check the condition of your sparkplugs
Andrew
Andr3w is online now   Reply With Quote
Old 08-23-2006, 03:45 PM   #4 (permalink)
Stealth Pilot
If this was the problem, and it wasn't taken care of, would it result in my car not starting?
Old 08-23-2006, 03:53 PM   #5 (permalink)
sky is the limit
3kgt's Avatar
Drives: 93 Vr-4
3kgt is an unknown quantity at this point
when your car bogs do you shift then it goes away till you build rpms? Then you have to shift early every time so it wont bog?
"It is a 2 ton warrior"..... and yes it will smoke your 1 ton ricer
3kgt is offline   Reply With Quote
Old 08-23-2006, 04:12 PM   #6 (permalink)
Drives: Red 1991 VR-4 (#3)
ZephTheChef Level 4ZephTheChef Level 4ZephTheChef Level 4ZephTheChef Level 4ZephTheChef Level 4
Fuel or spark issue, check the plugs, fuel filter, etc.
ZephTheChef is offline   Reply With Quote
Old 08-24-2006, 06:22 AM   #7 (permalink)
MiVR4TT's Avatar
Drives: 1992 Pearl VR4
MiVR4TT is an unknown quantity at this point
If you end up changing the plugs and wires, fuel filter, and confirm all the coil are good AND check the PTU check the base timing. I say to check this last because A) it shouldn't just get out of timing all of a sudden and B) the things listed above are much more likely to be the case.
Jason
MiVR4TT is offline   Reply With Quote
Old 08-24-2006, 09:24 AM   #8 (permalink)
Echo419's Avatar
Drives: '92 VR4, 95SL1, S13
Trader Rating: (18)
Echo419 Level 7Echo419 Level 7Echo419 Level 7Echo419 Level 7Echo419 Level 7Echo419 Level 7Echo419 Level 7
I had the EXACT same problem....and fixed it last night!!! get a Scanmaster(or you can just check the wires @ the throttle control sensor) hook it up. I'd be willing to bet it will show that the throttle's open when you're not pressing the gas and when you press the gas it drops to Zero.
In my case the wiring going to the TCS was fuct. we peeled back the wire cover to discover it. reconnected the wires and I was good to go!
also you may want to check for boost leaks. I didn't have any symptoms but we did it and found a couple, easy fix. G/L
p.s. I'd be more than happy to try and walk you through anything/help if I can.
www.fairtax.org
We ride around with Turbos the size of Lil' Bow Wow
Echo419 is online now   Reply With Quote
Old 10-10-2007, 07:04 AM   #9 (permalink)
King Detail
ProwlerGT's Avatar
Drives: 95 3000GT Base DOHC
Trader Rating: (11)
ProwlerGT Level 1ProwlerGT Level 1
Did you ever fix this? What was it? I have same problem now and I'm 2nd gen. Go figure.
I too had cracked wire covering at the TPS harness. I elec taped each wire individually and then wrapped them all up. TPS seems to work fine, but I guess I could check the harness again and make sure its not hanging on by a thread. Still would like to know how you resolved yours if you ever did.
I also have new MSD 8.5's, new Denso Iridiums, and new fuel filter all maybe driven for 1000 miles over the past 3 years as the car has been sitting up.
INFO LINKS FOR EVERYONE:
 ProwlerGT's Revival Thread | My Service Log | IAC | SENSORS | Hesitation Tracking List | NO3S.com
Lata,
ProwlerGT
"Those who know me, know my real name and more importantly how to say it right."
ThinkAbtIt on AIM | searcherrr on Yahoo IM | Email in profile
ProwlerGT is offline   Reply With Quote
Old 10-27-2007, 03:40 PM   #10 (permalink)
Drives: Soon: 92 3000GT VR4
FreeStyle786 is an unknown quantity at this point
Was this ever resolved?
FreeStyle786 is offline   Reply With Quote
