#31 (permalink) |
Mr. Cheese
I've had a couple boost controllers on my car and I also have an aftermarket boost gauge. If I have it set to 14 psi the boost gauge reads 14 psi, if 6 psi then it reads 6 psi... I'd go get those gauges looked at italiano, dont wanna ruin your motor cause your gauge is giving you false readings
MY DAILY DRIVER IS FOR SALE!!!
94 3000GT SL SALE THREAD 1992 Stealth RT/Twin Turbo ~ 62,000 miles ~ Stored every winter since new ~ Borla Exhaust ~ K&N FIPK ~ Autometer Boost Gauge ~ Datalogger w/MMCD ~ AEM Tru-Boost ~ DNP Y-Pipe and Preturbo Pipes ~ Catless ~ Tein S springs ~ Sitting at home waiting to be installed: 450cc Blacktop injectors, Walbro 255, SAFC, Turbo timer, Greddy Type S BOV, Brembro Cross Drilled rotors... so many parts... so little time ![]() Daily Driver: 94 3000GT SL w/99 conversion |
#33 (permalink) |
In Training
I've got my controller at .92-.95hkpa which is around 13.5PSI.
I logged when I turned it up, and was having 6-7 counts of knock at very high RPM. I haven't logged since, and might turn it up another pound or so. I changed my motor mounts which could have been causing some of that knock.
K/N FIPK ll 3SX Downpipe ll Joe P. MBC ll Vac. Redux ll Precat Elims ll NGK 8MM Plug Wires ll Evo 8 BOV ll Test Pipe ll 99 Lifters ll FP Hotwire ll Bilstein Struts ll H&R Springs ll Blitz Turbo Timer w/boost gauge ll SS brake lines ll '99 Headlights and Turns ll Hybrid Datalogger ll 3SX 2" Core Radiator ll ACPT 1pc CFDS ll F/R Solid Mounts ll Side Poly Mounts
Stealth owners....Get vinyl lettering for your calipers! |
#35 (permalink) |
TPW Educator
Mine is at 17psi max, but my car is modded to be able to take it.
If those are 9bs and you are getting 20psi, something is def. wrong and you are blowing in lots of HOT air. Find out if the fuel injectors are stock or aftermarket, it any other fuel mods have been done (hot wired the fuel pump for example), and find out for sure what turbos you have in there.
97 SLX
The SLX is leaving the East Coast 5/18/08 World's fastest fwdTT 97SL in Reading, PA 410 Ft/lbs of torque-steer and 390HP to the front wheels, making 1-3 gear useless @17psi. Built and tuned by 3SX 3SI member # 5422 |
