#11 (permalink) | |
Yank in the UK
Good idea.
Jim Matthews - Yorkshire, England, UKTeam3S, 3SI #30, GTOUK #155 http://www.the-matthews.com/stealth.html Jet Black '94 Dodge Stealth R/T Twin-Turbo AWD AWS 6-spd Active Suspension Damping, Ek2MFG dual-flex downpipe, Zorstec custom SS cat-back dual A'PEXi Super AVC-R Mk-I, MHI TD04L-13Gs, K&N FIPK, IPS SS Y-pipe A'PEXi Super AFC 5-knob, 450cc Black Tops, MirageCorp Logger Mobil 1 & Redline fluids, Hotwired Denso 1020 Pump, IPO/SX AFPR SCE 332x32/322x28 cryoed StopTechs, Wilwood proportioning valves Winter: stock alloys 17x8.5-46, Hankook Icebear W300 235/45VR17 Summer: Enkei RPM2 17x9-40, Yokohama AVS ES100 245/45ZR17 Track: Enkei RPM2 17x9-40, Yokohama A-032R Hcomp 275/40R17 My reliable daily driver since Feb 1997! ![]() |
#12 (permalink) |
fasten up and get ready for a learning curve. you really need to get the boost down to a safe 14psi. Learn datalogging, find out what turbo's you have. Do you have a safc what injectors. You could just have blow by and a bad guage. Search is your friend.
#13 (permalink) |
06 Cobalt SS Supercharged
Post some pictures up of the engine bay (multiple from different angles), the interior (preferably the instrument cluster and any gauges you have), and we may be able to help tell you some things, like some of the mods you have and some suggestions.
Your "cutting out" could also be spark blowout from the sounds of it, but I would more than likely bet its fuel cut as suggested if you're legitimately boosting 20psi.
My Cobalt SS Supercharged
Dyno: 228whp 204tq (w/CAI, Cat-back, S2 and 3.06" pulley) Mods: AEM Cold Air Intake || GM Stage 2 Tune || 42.5lb/hr Injectors || 2.9" S/C Pulley (3.35 stock) || Magnaflow Cat-Back Exhaust || NGK Copper Plugs || BWoody Solid Front Transmission Mount || Ingall's Engine Torque Damper || DC Sports Front Strut Tower Bar || 35% Carbon Black Tint || ARK Shorty Antennae ![]() Last edited by LittleGoose : 05-07-2008 at 10:53 PM. |
#15 (permalink) |
Removing the turbo timer isn't a big deal at all really, shouldn't cause you any problems. If you feel like you've done alot of heavy driving before you're about to shut it off, let it idle for 15-30 seconds or so, should be fine otherwise. Most people don't use them in 3/S's. It's like running high octane fuel when your car requires 87. Sure 93 is safer and more resistant to detonation, but you don't really need it.
#16 (permalink) |
well, actually, the turbo timer was dangling because the bolts vibrated out, and it just fell out of its holder thing and disconnected. but yeah, i can get some pictures of it after school since i dont have tennis practice (we've had like a match everyday almost, and that's why i post up so late at night usually, and i just finished my earth-science homework, but that only took like 15 minutes).
we haven't tampered with anything really. my dad actually turned down the boost on the g-reddy thing, and it was fine before that. and what exactly is a fuel cut. is it just like a rev limiter sort of? except it "cuts" the fuel so it doesn't over-do-it, so to say? |
#18 (permalink) | |
check that link out. |
#19 (permalink) |
ok, i took as many pictures as i could. i didn't really know what was the most important part of the engine, so i took alot. (and the exhaust, since that's what that fuel cut thing said from little goose's post....) and as for the fuel cuts, will they go away once i lower the boost? and why is the car doing it now, after all of those other times we drove it, and haven't touched a thing?
