#32 (permalink) |
In Training
I've got my controller at .92-.95hkpa which is around 13.5PSI.
I logged when I turned it up, and was having 6-7 counts of knock at very high RPM. I haven't logged since, and might turn it up another pound or so. I changed my motor mounts which could have been causing some of that knock.
K/N FIPK ll 3SX Downpipe ll Joe P. MBC ll Vac. Redux ll Precat Elims ll NGK 8MM Plug Wires ll Evo 8 BOV ll Test Pipe ll 99 Lifters ll FP Hotwire ll Bilstein Struts ll H&R Springs ll Blitz Turbo Timer w/boost gauge ll SS brake lines ll '99 Headlights and Turns ll Hybrid Datalogger ll 3SX 2" Core Radiator ll ACPT 1pc CFDS ll F/R Solid Mounts ll Side Poly Mounts
Stealth owners....Get vinyl lettering for your calipers! |
#34 (permalink) |
TPW Educator
Mine is at 17psi max, but my car is modded to be able to take it.
If those are 9bs and you are getting 20psi, something is def. wrong and you are blowing in lots of HOT air. Find out if the fuel injectors are stock or aftermarket, it any other fuel mods have been done (hot wired the fuel pump for example), and find out for sure what turbos you have in there.
97 SLX
World's fastest fwdTT 97SL in Phoenix 410 Ft/lbs of torque-steer and 390HP to the front wheels, making 1-3 gear useless @17psi. Built and tuned by 3SX First time to the track (Firebird) = Best 60ft 2.4 Best ET 13.8 , best trap 110.4MPH , picked up almost 30mph on the big end of the track. 3SI member # 5422 ![]() |
