Old 09-16-2008, 09:29 PM   #1 (permalink)
coolhandluke is an unknown quantity at this point
Default best plugs and wires?
Hey, was wondering what the best plugs and wires i should use for my vr4? Hoping to be running 14psi of boost
coolhandluke is offline   Reply With Quote
Old 09-16-2008, 10:06 PM   #2 (permalink)
92EuroDiamante's Avatar
Drives: Jdm D, D-LS, GTS
92EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 7
Default Re: best plugs and wires?
if your only replacing the wires then get stock replacements. as for the plugs im not sure since you are modding the boost im sure someone else will help you with that but anything NGK has always worked flawlessly for me. (although i hear on stock engines using iridium or those 4 platinum plugs can damange your pistons? is that true anyone?)
Godspeed Radiator,Custom Washer Reservoir Delete Cold Air Intake,Pro-Topline Pistons (old aussie co not topline) ,Custom Dual Exhaust,Homemade Resonated test pipe,Unorthodox underdrive pulley, Stock+Aftermarket Air Ride System, Lowered, Active Aero.Beefed up Tranny (long story), Sniper wet nitrous kit (needs to be tuned)
92EuroDiamante is online now   Reply With Quote
Old 09-16-2008, 10:25 PM   #3 (permalink)
Profesional Insomniac
veerfour05's Avatar
Drives: 93 VR4
veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7
OEM wires and either NGK coppers or platinums for plugs. Run about a .032"-.036" gap. Coppers get better spark but the platinums last longer. I run coppers and change them out every spring.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
Originally Posted by Polygon View Post
As for hijacking the thread, we've more than hijacked it. We've hijacked it, taken it hostage, killed one to let them know we are serious, and are now demanding a helicopter for escape.
veerfour05 is offline   Reply With Quote
Old 09-16-2008, 10:46 PM   #4 (permalink)
stans3000gt's Avatar
Drives: 1992 VR-4x2, 1993 SL
stans3000gt Level 7stans3000gt Level 7stans3000gt Level 7stans3000gt Level 7stans3000gt Level 7stans3000gt Level 7stans3000gt Level 7stans3000gt Level 7stans3000gt Level 7
Can you safetly gap platinums?? what do you use to gap them??
Also they come pregaped dont they???
stans3000gt is offline   Reply With Quote
Old 09-17-2008, 08:08 AM   #5 (permalink)
NOTADSM
Polygon's Avatar
Drives: '89 GTC & '91 R/T TT
Trader Rating: (11)
Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7
Platinum/Iridium NGK or Denso plugs if you're leaving it stock or it has a good tune and you're going to leave it alone. Go with NGK coppers if you're in the process of tuning/modding since they are good but cheap in case you foul them. For wires stick with OEM or get the MSD wires with the L-shaped boot. The straight boot has issues with arcing on the head. The L-shaped boots are the more expensive of the two.
Polygon is offline   Reply With Quote
Old 09-17-2008, 08:09 AM   #6 (permalink)
Grandpa
EVILTWIN's Avatar
Drives: 07Accord, 03 C5 ann.
EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7
if you dont mind changing plugs more often I'd go with coppers as well. Stock wires should be just fine.
If you dont want to change your plugs as often then go with the platinums. Its really not that hard, and the more you change your plugs, the faster you will get at doing it.
And you can re-gap platinums, you just have to be more careful about doing it.
Set the gearshift, for the high gear of your soul.
Chuck Norris can win a game of Connect Four in THREE MOVES
I'm an Equal Opportunity Annoyer!
EVILTWIN is offline   Reply With Quote
Old 09-17-2008, 10:42 PM   #7 (permalink)
carsrfun is an unknown quantity at this point
sorry for the hijack but does anyone have a PN for the coppers by chance, sendin my girl to get the parts and wanna make sure she gets right ones... thanks in advance
carsrfun is offline   Reply With Quote
Old 09-17-2008, 10:46 PM   #8 (permalink)
The car. The legend.
chriskart09's Avatar
Drives: 3000GT VR4
chriskart09 Level 5chriskart09 Level 5chriskart09 Level 5chriskart09 Level 5chriskart09 Level 5chriskart09 Level 5
I'm using the NGK Iridiuns. Works really good on the stock setup, no problem!
____________________________
Booooooooooost
chriskart09 is offline   Reply With Quote
Old 09-17-2008, 11:16 PM   #9 (permalink)
veerfour05's Avatar
Drives: 93 VR4
I run NGK BKR7ES-11s on my car.
Old 09-17-2008, 11:32 PM   #10 (permalink)
Apache's Avatar
Drives: '97 3000GT VR-4
Apache Level 1Apache Level 1
Also interested in this as I'm going to be changing my plugs and wires later this month. Was planning on using Denso IK24 Iridiums with NGK plug wires. The car is pretty much stock other than a downpipe and gutted precats, though it will have DR-500s running stock boost next month. Any downsides to this setup?
Apache is offline   Reply With Quote
