Old 06-16-2008, 04:38 PM   #1 (permalink)
BShellcom's Avatar
BShellcom is an unknown quantity at this point
Question Base to R/T Tail Light conversion!
Hey I just got a 1992 base model stealth and I love it. I put the rear end from an R/T on it and the tail lights will not function properly. Going from a three light 2057 set up to a 2 light set up leaves the leads from the brake and turn signals to canel each other out but they both need to utilize the bright element in the single 2057 bulb on each side. So.... do i need a module or relay, different wiring or switch to make this work properly??? Somebody help before I get pulled over!!! lol....
BShellcom is offline   Reply With Quote
Old 06-16-2008, 04:58 PM   #2 (permalink)
Oh SNAP!!!
mywetdream's Avatar
Drives: 94 TT, 69 427 vette
Trader Rating: (19)
mywetdream Level 2mywetdream Level 2mywetdream Level 2
Default Re: Base to R/T Tail Light conversion!
You have to get the R/T tail light harness and splice it into your current wires..
If you feel I have answered your question..leave me some rep...thanks
**1ST place RMG 07 best engine**
Like the snake the BITE must be felt and not seen, goin super, until then super slow want some!!!
1st car with the Enkei RZ-5 18''x8.5''
*534x306*
1994 Dodge Stealth R/T TT~Pearl Yellow
mywetdream is offline   Reply With Quote
Old 06-16-2008, 05:02 PM   #3 (permalink)
BShellcom's Avatar
I did this.... But to no luck... I tried wiring those 4 wires all different ways but both the brake and the signal leads go to the same bulb. the signal will work until you step on the brake then all signals turn on and stay on until brake is released... thank you for the response though...
Old 06-16-2008, 05:39 PM   #4 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (77)
You need the RT flasher module.
Old 06-17-2008, 04:29 PM   #5 (permalink)
BShellcom's Avatar
I read another article about how the connections were different on this flasher module. Is that true and where is the module located at... Thank you for your patience I am new....
~B~
