bad tps???? does it cause the engine to stall???? - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 09-18-2010, 05:16 PM   #1 (permalink)
atenzany62's Avatar
Drives: 02 WRX
atenzany62 is an unknown quantity at this point
Feedback Score: 8 reviews
Default bad tps???? does it cause the engine to stall????
so ive been having idling issues and stalling issues. i have cleaned and checked resistance on the iac it was good. but people recommanded to buy a new one. so i bought a new one from rockauto. put it on with a brand new o-ring gasket. car still stalls..
this is during cold starts. when i start it up and try to give it some throttle. the throttle would NOT respond, and the engine stalled. so giving it throttle to keep the engine going doesnt work. is it a bad tps?
06 Mazda6s - Gone
02 Subaru Impreza WRX - Sold
95 Subaru Impreza USDM WRX engine JDM STi exterior swap - Sold
05 Dodge SRT-4 - Sold
94 Dodge Stealth RT turbo - Gladly Gone
95 Mitsubishi 3000GT VR-4 - Pampena 3.1L, Volks, 97 front with CF splitter etc. - Gladly Sold
02 Infiniti Q45 sport package - Custom molded WALD lip, 18" Enkei 2011 Maxima wheels - Sold
04 Honda S2000 - Invidia Q300 catback, Invidia test pipe, CT Engineering intake, Mugen replica lip - Sold
04 BMW Z4 3.0i - M3 CSL wheels, CF lip, flat black grille - Sold
04 Nissan 350z touring - Nismo V2, 19" Rays - Sold
98 Honda Accord - Current DD lol
atenzany62 is offline   Reply With Quote Quick reply to this message
Old 09-18-2010, 06:51 PM   #2 (permalink)
RealMcCoy's Avatar
Drives: 92 RT/TT, 96 Cobra
RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3
Feedback Score: 48 reviews
Default Re: bad tps???? does it cause the engine to stall????
Have you tested anything..? do you have any reason to suspect a TPS? Are there any codes?
Have you adjusted the minimum idle to spec, and checked/adjusted the idle switch? have you checked for boost leaks?
RealMcCoy is offline   Reply With Quote Quick reply to this message
Old 09-18-2010, 06:54 PM   #3 (permalink)
^^My name is April^^
dbest671's Avatar
Drives: Spyder VR4/SRT8/CTSV
dbest671 Level 2dbest671 Level 2dbest671 Level 2dbest671 Level 2dbest671 Level 2dbest671 Level 2
Feedback Score: 92 reviews
I was told sometimes the dashpot would stick (little black hat thing attached to the throttle body), but I don't know if that would cause your problem.
dbest671 is offline   Reply With Quote Quick reply to this message
Old 09-18-2010, 07:02 PM   #4 (permalink)
atenzany62's Avatar
Drives: 02 WRX
i made a pressure tester with a tire stem. and i have a 12v compressor. i plugged it in and the gauge on the compressor didnt read anything. i asked if there are any hoses i need to pull off and plug for the pressure test nobody answered me... last week when the car actually ran it had no codes.
and on 3si wiki it said only to adjust whatever the idling screw is ONLY when the car warms up... i couldnt even get it to warm up plus when i first got the car the idle was perfect and i never touched the idle adjusting screw so im assuming its within specs.
Old 09-18-2010, 07:16 PM   #5 (permalink)
RealMcCoy's Avatar
Rob Beck has some pretty good info in his procedure notes for his pressure tester.
http://www.3si.org/forum/f4/intake-p...-t6061-206269/
Getting the idle switch set correctly, and setting the minimum idle correctly when warm, will effect how the computer reacts to a cold start
Old 09-18-2010, 07:28 PM   #6 (permalink)
atenzany62's Avatar
Drives: 02 WRX
i remember there were 2 that affects idle one was called the biss and another called the sas. 3s wiki said not to touch the biss at all unless i know someone have messed around with it before. the sas was the one that 3s wiki said only to adjust when warm.
are you speaking of the sas?
Old 10-10-2010, 06:48 PM   #7 (permalink)
full of indifference
Deebs's Avatar
Drives: '91 Stealth R/T
Deebs is an unknown quantity at this point
Feedback Score: 1 reviews
I've been going through the same thing... Does your car stall after a certain number of seconds? Cause that's what mine has been doing, first we replaced the MAF and now it seems to think the injector is the problem. Any updates?
Stealth R/T N/A
Bone stock except Bulldog security system.
Doing 120k service, then installing light controls for some footwell/ cargo LED's.
Deebs is offline   Reply With Quote Quick reply to this message
Old 10-10-2010, 08:08 PM   #8 (permalink)
atenzany62's Avatar
Drives: 02 WRX
no updates been having the problem for a month... it USED to turn on for 2-3 seconds, then it got worse. it turned on for 1 second and stalls. now it just turns on and off right away.
Old 10-11-2010, 01:14 AM   #9 (permalink)
ken9396's Avatar
Drives: 93 Stealth/96 3000GT
ken9396 is an unknown quantity at this point
Feedback Score: 0 reviews
Have you check to see if your connectors are fully engaged on the VIC motor on the driver side of the intake plenum?
ken9396 is offline   Reply With Quote Quick reply to this message
Old 10-13-2010, 12:16 PM   #10 (permalink)
Drives: '94 VR-4 w/JDM motor
Hackurs is an unknown quantity at this point
Do you hear any clicking or buzzing when it stalls, either in the bay, or inside the car?
Hackurs is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
Random Question
