Old 07-13-2008, 09:25 PM   #1 (permalink)
steveyg348's Avatar
Drives: 1991 Stealth ES
steveyg348 Level 5steveyg348 Level 5steveyg348 Level 5steveyg348 Level 5steveyg348 Level 5steveyg348 Level 5
Default Another lifter tick question
I know this has been asked many times, but when I researched it I couldn't find and answer for what might be wrong when you continually have the tick at running temperature but not when started cold.
Actually, maybe about 20% of cold starts I get it right away but thats about it. I heard there might be an actual problem if it persists when running warm.
Last two oil changes I did were royal purple and did the rev solution but nothing.
steveyg348 is offline   Reply With Quote
Old 07-13-2008, 10:49 PM   #2 (permalink)
broke joke
zba857's Avatar
Drives: 6spd 92'
zba857 is an unknown quantity at this point
Default Re: Another lifter tick question
What car do you drive? weight oil? your location? etc..
zba857 is offline   Reply With Quote
Old 07-14-2008, 01:43 AM   #3 (permalink)
steveyg348's Avatar
I have a '91 es and I live in NY/VA.
I used Royal purple from my friend because he was the one who first mentioned it my cure the problem, I didn't know/think they made it in different weights for some reason.
If I had to guess it was probably 10-30
Old 07-15-2008, 10:40 PM   #4 (permalink)
broke joke
zba857's Avatar
Drives: 6spd 92'
Your car might be happier with a 10-40 for the summer.
Royal Purple Motor Oil
Bob Is The Oil Guy
Have you tried seafoam or Auto-Rx?
Old 07-18-2008, 02:42 AM   #5 (permalink)
steveyg348's Avatar
Well I'm do for an oil change so I'll go 10-40 Royal purple this time.
Thanks, I haven't tried either of the additives, I have never really trusted that, but if it persists do you suggest either one more than the other?
Old 07-18-2008, 07:32 AM   #6 (permalink)
4everstealthy's Avatar
Drives: 91 stealth
4everstealthy Level 74everstealthy Level 74everstealthy Level 74everstealthy Level 74everstealthy Level 74everstealthy Level 74everstealthy Level 74everstealthy Level 7
get the nicest oil filter you can find it made a big difference with my tick
Kawasaki Ninja ZX-6R- full muzzy exhaust, k&n drop-in
4everstealthy is offline   Reply With Quote
Old 07-18-2008, 07:37 AM   #7 (permalink)
bane of unintelligence
inperfectdarkness's Avatar
Drives: dreaming of a TT ecu
Trader Rating: (13)
inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7
^that sounds like voodoo to me. and you'd be the first i know of whose filter solved lifter tick.
slightly heavier oil should stop the tick. of course...you hasten the aging of your engine if you run significantly heavier oil.
if you're good with fiberglass...REALLY good...pm me. i have work for you.
ditto if you're an automotive painter in middle Georgia.
Originally Posted by beepbeep View Post
I got neg rep'd when I offered to give my hubby a bj. If THAT doesn't demonstrate the importance of the rep system, I don't know what does!
inperfectdarkness is offline   Reply With Quote
Old 07-20-2008, 01:08 AM   #8 (permalink)
steveyg348's Avatar
Alright, sounds good guys, thanks for the help. I should be doing an oil change in a few days here.
Old 07-22-2008, 12:16 AM   #9 (permalink)
steveyg348's Avatar
Changed my oil, tick is gone for now, thanks alot.
