Old 07-14-2008, 07:41 PM   #1 (permalink)
Here for the cake
theeyebrower's Avatar
Drives: 92 Stealth base
Trader Rating: (9)
theeyebrower is an unknown quantity at this point
Default Amsoil vs. Royal Purple motor oil?
I know people have had Royal Purple's motor oil stop the ticking they were hearing from their lifters. Has anyone had the same experience with Amsoil's motor oil? Trying to make a decision on which one to try next oil change, and I am looking for any insight into it. I am currently leaning towards Amsoil, but whether anyone has had the ticking noise go away with Amsoil will be a big factor. Thanks!
theeyebrower is offline   Reply With Quote
Old 07-14-2008, 07:46 PM   #2 (permalink)
the word ****** is ******
blackrussian's Avatar
Trader Rating: (15)
blackrussian is an unknown quantity at this point
Default Re: Amsoil vs. Royal Purple motor oil?
You will get soo many different opinions on this, there is no solid answer.
Originally Posted by jackhammer
Something tells me there wont be any enimas given or taken in the heat of the drunken moment
blackrussian is offline   Reply With Quote
Old 07-16-2008, 09:57 AM   #3 (permalink)
Mitsubishi Junkie
Joel_CA's Avatar
Drives: 2 Pearly Whites
Trader Rating: (7)
Joel_CA Level 1Joel_CA Level 1
Royal Purple is an excellent oil- but in no means is the actual fix for lifter tick. For some it has worked- for others it hasn't. The results should be the same for Amsoil- hit or miss.
If you're looking for a true fix- you can either clean out your existing lifters in diesel fuel or replace them with the updated style lifters. Note that even the newer style lifters will develope a tick if the engine doesn't get regular oil changes. When i first bought my 92VR4- it had lifter tick that didn't go away regardless of what oil i used. I eventually replaced the lifters. While doing so- i found that it already had the newer style lifters in em.
JJ
1992 3000GT VR4 (tastefully modified) & 1996 STEALTH RT/TT #47 (restoration work in progress)
Joel_CA is offline   Reply With Quote
Old 07-16-2008, 07:05 PM   #4 (permalink)
Here for the cake
Trader Rating: (9)
thnx for the info!
