Old 03-17-2008, 06:32 PM   #1 (permalink)
herman1117 is an unknown quantity at this point
Default 91 TT problems
Can a bad fuel pressure regulator cause my 91 TT to jerk on acceleration and cause a popping noise?
herman1117 is offline   Reply With Quote
Old 03-17-2008, 10:09 PM   #2 (permalink)
Profesional Insomniac
veerfour05's Avatar
Drives: 93 VR4
veerfour05 Level 2veerfour05 Level 2veerfour05 Level 2
Default Re: 91 TT problems
Possible, what makes you think you have a bad FPR?
veerfour05 is offline   Reply With Quote
Old 03-18-2008, 09:00 AM   #3 (permalink)
3/S enthusiast
andyvr4's Avatar
Drives: 91 VR-4, 99 Zx2
andyvr4 is an unknown quantity at this point
It can, but there's also a lot of other things that can cause that as well. The best way to check and see if the FPR is causing the issue would be to get an aftermarket fuel pressure gauge and see what fuel pressure you're getting setting at idle. You should see somewhere around 45 psi. If you're seeing significantly higher than your FPR is getting over ran.
andyvr4 is offline   Reply With Quote
