Old 06-14-2008, 07:03 PM   #1 (permalink)
dwd58 is an unknown quantity at this point
Default 6-speed
I saw the production numbers for the different years of the VR 4, but just wondering how rare the 6-speed transmission is. What years came out with the 6-speed, and how many did they make?
dwd58 is offline   Reply With Quote
Old 06-14-2008, 07:08 PM   #2 (permalink)
never a dull moment
DCIV's Avatar
Drives: 92 VR4
Trader Rating: (12)
DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7
Default Re: 6-speed
94-99 for the 6 speed, 91-93 for the 5 speed.
Coop
To many mods to list.
Old 06-14-2008, 10:09 PM   #3 (permalink)
*** addict
trung87's Avatar
Drives: 97 base 3000gt
trung87 is an unknown quantity at this point
Default Re: 6-speed
Yup. If you want a 6 speed VR4 it'll be in the 1994-1999 years. Prior to that the VR4's come with a 5 speed manual but some people have done a 6 speed swap.
trung87 is offline   Reply With Quote
Old 06-14-2008, 10:18 PM   #4 (permalink)
gearheadvr4's Avatar
Drives: Pucking VR4
Trader Rating: (24)
gearheadvr4 Level 1gearheadvr4 Level 1
Default Re: 6-speed
Yup, you have to change a bunch of stuff but it's definately doable.
You'd need the 6 speed trans (of course), transfer case, driveshaft or at least the front piece, differential, and probably the shifter cables too. Axles are the same for front and rear.
I did mine and it was by far the best mod.
Permanently broke! But her soul will be reborn into another VR4 soon. 92 VR4- Rebuilt engine with forged crank, TD05 manifolds with MHI EVO 3 16g, 6 speed conversion done, Maximal Solid Mounts, front mount 3" w/custom intercooler and intake pipes, OFE Stage 3 Clutch (from Southbend Clutch), SS clutch line, SS brake lines, SS oil and coolant lines, borla exhaust, stillen downpipe, egr block-off plates, LC-1 Wideband, blitz dc2 turbo timer, hks ssbov, Maft Pro speed density, Blitz SBC i-D III boost controller w/ Power Meter, k&n filters & custom intake pipes, gutted cats, 18x9 blitz type 03 wheels wrapped in Nexen N3000 tires, intrax springs, adj. control arms, 97 frontend and side conversion, 99 center tail light piece (<--adds at least 20hp on the dyno )
gearheadvr4 is offline   Reply With Quote
Old 06-15-2008, 05:03 AM   #5 (permalink)
Default Re: 6-speed
I was told that 1994 had some 5 speeds produced and some 6 speeds in the vr4, but I take it that in the years after that, only 6 speeds were produced in the vr4's?
Old 06-15-2008, 05:06 AM   #6 (permalink)
nylander's Avatar
Drives: '93 R/T NA, '02 WRX
nylander is an unknown quantity at this point
Default Re: 6-speed
Negative! All 94+ TT's are 6-speed.
nylander is offline   Reply With Quote
Old 06-15-2008, 07:44 AM   #7 (permalink)
Paid Member
Alt0id's Avatar
Drives: '94 3000GT SL
Alt0id Level 4Alt0id Level 4Alt0id Level 4Alt0id Level 4Alt0id Level 4
Default Re: 6-speed
What you may have been told is only the vr-4 and rt/tt had the 6 speed, n/a had 5 speed or auto
Alt0id is offline   Reply With Quote
Old 06-15-2008, 10:46 PM   #8 (permalink)
Hammer
Drives: 95 3000gt vr4 stock
Hammer Level 1Hammer Level 1
Default Re: 6-speed
I think there are more 91-93 made than the total 94-99 model run.
I think it is even as high as a 2 to 1 ratio.
Hammer is offline   Reply With Quote
Old 06-16-2008, 07:07 AM   #9 (permalink)
3/S enthusiast
andyvr4's Avatar
Drives: 91 VR-4, 99 Zx2
andyvr4 Level 3andyvr4 Level 3andyvr4 Level 3andyvr4 Level 3
Default Re: 6-speed
Production numbers
andyvr4 is offline   Reply With Quote
