Old 07-23-2008, 01:49 AM   #1 (permalink)
rowekmr is an unknown quantity at this point
Default 4 wheel steering
The only vehicles advertised locally with 4 wheel steering is the 3000gt VR, does the Stealth TT also come with that option. It seems like a nice option is it trouble prone? If the car is heavily modified can it handle the stress?
rowekmr is offline   Reply With Quote
Old 07-23-2008, 02:18 AM   #2 (permalink)
e46m3's Avatar
Drives: BMW M3 / Mitshi VR4
e46m3 Level 3e46m3 Level 3e46m3 Level 3e46m3 Level 3
Default Re: 4 wheel steering
Personally I find it to be a bit of a gimmick, and for me, found it made me think the car was more unstable if I tried to drive it quicker.
For example, if I felt the back step out, I'd try to steer into it to correct it(out of driving habit) but the 4WS had tried to correct it to and just didn't make it feel like a "drivers" car.
I am sure some people love it, but it's not for me.
Pro's of removing it:
  • Your car will be 40lbs lighter
  • Less stress/slight more BHP from the engine as not having to contstantly drive the oil pumps
  • Another thing less to go wrong
Con's:
lol
e46m3 is offline   Reply With Quote
Old 07-23-2008, 02:21 AM   #3 (permalink)
Profesional Insomniac
veerfour05's Avatar
Drives: 93 VR4
veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7veerfour05 Level 7
IIRC the Stealth TTs had 4WS with the exception of the 96, if anyone can correct me feel free.
veerfour05 is offline   Reply With Quote
Old 07-23-2008, 03:52 AM   #4 (permalink)
Is there a way I can look to see if it has 4ws, sometimes the owners aren't sure of the options on their vehicles.
Old 07-23-2008, 03:55 AM   #5 (permalink)
veerfour05's Avatar
Drives: 93 VR4
It's been a while since I fired mine up but I think there is a light that will come on when you turn the key to run for the bulb check that says something about 4WS oil.
Old 07-23-2008, 04:10 AM   #6 (permalink)
e46m3's Avatar
Yeah, correct.
It says "4WS Oil" in red.
Old 07-23-2008, 07:32 AM   #7 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7
91-94 stealth TTs had AWS.
95-96 TTs do not.
Easiest way to check is to look at the chassis code on the firewall.
Z16A - AWD AWS chassis
Z15A - AWD non-AWS chassis
Z11A - FWD chassis
As for pros and cons, road race guys are split about 50-50 on its usefulness. I didn't like it much (and removed it), but a lot of people find that it gives them greater stability and higher speeds at turn-in. If you search for AWS and user Erron Spalsbury, you'll pull up several threads in which he explains why he likes it, his results, etc.
Clint
The Pansy Patrol
1994 Mazda Protege DX: 260K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech XP8/AX6, 15x7 +30 Kazera KZ-M w/ Avon Tech Ra slicks, other crap here and there (like an air filter that doesn't have 1/4 of a million miles), arguably the fastest piece of shit in New England and no one can do anything about it
Struggly is offline   Reply With Quote
