Old 05-05-2008, 02:42 PM   #11 (permalink)
turbochris's Avatar
Drives: 1991 VR4
turbochris is an unknown quantity at this point
Default Re: 1991 VR4 questions
Don't forget about the output shaft,corroded brake/streering lines,17year old intercoolers....and,and,and.Seriosly,these cars are not a wise choise if you live on a budget.As a daily driver,unless you do a complete rebuilt,they are pretty much useless if you ask me.
turbochris is offline   Reply With Quote
Old 05-05-2008, 03:10 PM   #12 (permalink)
soaking it up
nawz8r's Avatar
Drives: '91 TT, '02 A'lanche
nawz8r is an unknown quantity at this point
It's been sitting in the sun for sure. A good cleaner wax and a buffing machine can really shine the paint up. It basically takes off oxidation and a layer of paint with it which will show on the pad, then wax the H out of it with a good wax. Be careful not to buff one spot too long, or could "burn" it. If you were to get the car - something to try before repainting.
It's prob due for wheel and carrier bearings with that mileage - $900 in parts. But maybe they've been replaced? Good luck
nawz8r is offline   Reply With Quote
Old 05-05-2008, 03:25 PM   #13 (permalink)
HLxDrummer's Avatar
Drives: 3000GT, '71 Mustang
HLxDrummer is an unknown quantity at this point
Whats up with the different wheel in the back? I doubt it would mess up the VCU since the rear end would make up for the difference but probably isn't good for it.
1994 3000GT SL
Newly Aquired Red 1993 VR4
HLxDrummer is offline   Reply With Quote
Old 05-05-2008, 06:30 PM   #14 (permalink)
O_ROD's Avatar
Drives: 1991 RT/TT
O_ROD is an unknown quantity at this point
Looks like a fun project, but I'd only buy it if that's your intentions. It's not the up front price that's important with a VR4, it's the aftermath of owning it and getting it up to snuff!
P.S. That's not an HKS Super Dragger ehxaust
P.S.S. If you keep TT's stockish and keep up with the maintenance, they ARE reliable.
//OPEN FILTER||EVO 9 BOV||GREDDY PROFEC B||CUSTOM DP NO CATS||TEINS||BILSTEINS\\
O_ROD is offline   Reply With Quote
Old 05-05-2008, 09:24 PM   #15 (permalink)
damoose212001's Avatar
Drives: Eagle Talon
damoose212001 is an unknown quantity at this point
Exactly, the problems go on and on. And we only gave you a couple of the more common problems. Look at small things too, such as any bent rims, condition of tires, alignment, the list just goes on and on. I'm currently not a VR4 owner myself, but I do assure you when I do own one, it will be the right one. I also made sure to wait until I graduated school, and got a decent job so I know I'll be able to afford anything this car throws at me. Honestly, it's probably not what you want to hear, but I'd buy a SL in your shoes, and think about it, you're still the kid in school with a sweet looking over 200 horsepower car. If you don't want to go that route, just keep waiting, there will be decent deals around, maybe for about 5 grand you can get a steal on a nice 1st gen. I'm actually looking at one for 6,500 out in Jersey that has 59,000 miles, believe me, patience is key, I let my Talon teach me the hard way bud, don't let it happen to you.
damoose212001 is offline   Reply With Quote
Old 05-06-2008, 11:23 AM   #16 (permalink)
One Sinister Motha Sucka!
Sin'sVr4's Avatar
Drives: 91 VR4/94 Wrangler
Sin'sVr4 is an unknown quantity at this point
Where to begin...I bought mine with the guy telling me that it had a fresh rebuilt engine and tranny 30K miles ago. Well, I started out by replacing the interior. $650...The suspension was redone as all parts still have tags and stickers on them including the drive shaft. Next, was little things like oil cooler feed and return lines...$130. Heard a knock, took it in and the 5th gear bearings and spring destroyed all my gears...so bought new gears and syncros...$1500, replaced next the cam seals and all gaskets....$200 (labor too)...Then bought new turbos..$1100...then once all that was together there was another knock...this time from the bottom end. Rod bearings were worn to the brass...Not spun..more $$$!! New oem forged crank $730, new clevite bearings..$85, plus when I pulled the rods and pistons, rings were bad and cylinders had piston slap...bored out .030 over and bought new IPS Ross pistons...$640...new water pump...$120, new oil pump $160, new rear moutor mount, new valve stem seals, egr block off plate.................It never ends!!!! Plus Im doing the 98 conversion....OMFG!!!! PLus labor!!!! add that up plus $3000 in labor plus $6400 for the car, plus $800 for the system!!! plus about another $2000 for guages, a-pillar pod, datalogger and cables, Greddy profec b spec II EBC, 560 injectors, 255 walbro, $800 borla, $300 safcII, plus gt-pro FMIC...$2500............IM GONNA BE SICK...All in 5 months
ALMS FOR THE POOR!!!!
MIke
PS If I could do it all over, .........I would cause she's gonna be mean and beautiful!!
91 Vr4, TDO4L 13T's, heads ported and polished, oil cooler, new vss, new valves, springs, rebuilt engine with 99 big bore lifters, Fel-pro head Bolts, IPS Ross (.030) Pistons and Rings, brand new forged mitsu oem crank, clevite bearings, all new gaskets and seals, new oem oil pump, new water pump, all new gears and synchros(1-5 and reverse) new oem motor mounts, Tein S Springs, 99 rear Garnish, Greddy Profec-B Spec II EBC, evo8 560cc injectors, Apexi SAFC-II, walbro 255 FP, 120k, hks SSQV, borla 3", downpipe, gt-pro FMIC, XTD stage 3 racing clutch, Brand new two tone custom interior, x2 Kicker Comp 12" subs, infinity Kappa 3 stage 6x9's, 98 conversion!
Sin'sVr4 is offline   Reply With Quote
Old 05-06-2008, 12:13 PM   #17 (permalink)
Moderator
Lord Warlock's Avatar
Drives: 2004 SVT Cobra,91TT
Trader Rating: (9)
Lord Warlock Level 5Lord Warlock Level 5Lord Warlock Level 5Lord Warlock Level 5Lord Warlock Level 5Lord Warlock Level 5
Join the ranks of those who feel we've been taken advantage of by our cars. Not that we gave up on them, but the fact that they keep sucking anything green or shiny from our pockets.
Lord Warlock is offline   Reply With Quote
Old 05-06-2008, 12:42 PM   #18 (permalink)
GTCUL8R
Polygon's Avatar
Drives: '89 GTC & '91 R/T TT
Trader Rating: (11)
Polygon Level 2Polygon Level 2Polygon Level 2
I'd agree. Only take it on as a project as it will make a crappy DD until you get it fixed.
Polygon is offline   Reply With Quote
Old 05-06-2008, 02:32 PM   #19 (permalink)
pretty much a noob
Gushers248's Avatar
Drives: 4x4 dime
Gushers248 is an unknown quantity at this point
Project was the basic plan, just drive it for a few months this summer and rebuild most of it over the next year and drive it in the summer again.
He said HKS dragger, maybe there were two models? I'm not sure
The wheels in the back on both sides were his stock rx7 wheels. he parked the car and since he built his rx7 from the ground up he had extra rims because he got a flat and didn't want to run a donut (same size diameter tire) and then he parked it because he got the rx7 up and running.
I've got a truck as a daily that I'd keep along with that car. More of a fun summer/weekend car
If only insurance wasn't so high...
Gushers248 is online now   Reply With Quote
Old 05-06-2008, 05:06 PM   #20 (permalink)
Moderator
Trader Rating: (9)
You'll notice we're being kind and understanding, while warning you off as best we can, the cars are definitely fun to drive when in good shape, and look different enough that they still stand out on the street, the biggest concern is not to overinvest in the project, its real easy to get upside down considering most 1st gens are only worth 5-8k. I threw 20k into mine in about a 2 year period, knowing it wouldn't return it. At one point you'll just decide that's enough. It is a very good thing to have a different daily driver, so you can live through the down periods better.
91 Stealth TT Stillen Intake, Stillen DP, DN Y Pipe, HKS EVC IV, GReddy BOV, Burlwood Dash kit, New Katzkins, OEM Short Block, RPS Max Street Clutch, Denso 310lph fuel pump, 13G Turbos, Borla exhaust, 550 DR Injectors, HKS SAFC, 2 gauge pod CF A/F gauge, autometer boost gauge. Custom vented blisters, New Valves, rebuilt heads, timing belt, new bearings and pistons. 35k invested.
Other cars: 1969 charger R/T SE, 04 SVT cobra
