Old 10-31-2007, 08:21 AM   #1 (permalink)
06 Subaru STI
scrapiron7's Avatar
Drives: 06 Subaru STI
Trader Rating: (6)
scrapiron7 Level 3scrapiron7 Level 3scrapiron7 Level 3scrapiron7 Level 3
Default 120k maintenance package ordered!
I'm sitting at 114,700, so a little while to go yet, but I went ahead and ordered my parts today from Rockville. They had the best prices on everything, and some nice package deals. Here's what I got
Hydraulic timing belt tensioner
Timing belt
Timing belt idler pulley
Timing belt tensioner pulley
water pump, o-ring and gasket ($299 for above parts bundle)
Oil return line gaskets -- part# MR258477 $1.05 each
oil pump w/front main seal ($140 for oil pump and oil pump gasket)
oil pump gasket
oil pump pick-up tube and gasket
oil filter assmembly gasket
oil coler bypass valve -- part# MD356695 $24.47
main bearings, rod bearings, thrust bearings (full sets)
camshaft seals -- part# MD152603 $6.85 each
valve stem seals -- part# MD307343 $3.34 each
valve cover gaskets -- part# MD186786 $14.06 each
spark plug gaskets -- part# MD186787 $4.04 each
throttle body gasket -- part# MD180361 $1.78
intake manifold plenum gasket -- part# MD143791 $6.70
rear turbo intercooler pipe o-ring -- part# MD090788 $3.66
turbo feed line copper crush washers
oil cooler line copper crush washers
$871 shipped for all that, not bad. I may do accessory belts when the time comes, but they look to be pretty new, so I didn't bother to order them.
Also got a nice EGR block off kit that will be installed at the same time.
2006 Subaru STI | Crystal Grey Metallic
APS 65mm Intake | SPT Catback | Invidia Downpipe | Cobb AP Stage 2
350HP / 392 lb-ft
scrapiron7 is offline   Reply With Quote
Old 10-31-2007, 09:09 AM   #2 (permalink)
Drives: 92 VR-4
S2Kto3KGT is an unknown quantity at this point
Default Re: 120k maintenance package ordered!
Sounds like you got a great deal. You will have your work cut out for you when it comes time do the install.
Thats good to be prepared that way you will have your parts on hand once you get to that point. Is Rockville, IPS Motorsports?
S2Kto3KGT is offline   Reply With Quote
Old 10-31-2007, 09:17 AM   #3 (permalink)
Certified Car Nut
JeffWVR4's Avatar
Drives: Like a Grandpa
JeffWVR4 Level 3JeffWVR4 Level 3JeffWVR4 Level 3JeffWVR4 Level 3
Are you doing a 120K or a rebuild? You wouldn't need to add much more than a set of rings, head gasekts, and a rear main seal to your list to go ahead and do a rebuild. And to replace all the stuff you listed, you'd be better off pulling the engine out of the car anyway.
Jeff W.
Red '92 VR4 213,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, 1/4 mile at a time, the rest was easy
Currently has the broken rod mod.
Big 16G Turbos w/adapter plates, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, Pre-cat eliminators w/dump tubes, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, DR Fuel Pump Hotwire Kit, South Bend FE/SS clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, PwerStop/Stillin rotors, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi wheels, 2-tone all-leather Interior.
JeffWVR4 is offline   Reply With Quote
Old 10-31-2007, 10:09 AM   #4 (permalink)
06 Subaru STI
scrapiron7's Avatar
Trader Rating: (6)
Rockville is actually a Mitsu dealer, and they give a nice discount to 3SI members. They deal OEM parts only.
http://mitsupartsdirect.com/index2.html
Old 10-31-2007, 10:14 AM   #5 (permalink)
06 Subaru STI
scrapiron7's Avatar
Trader Rating: (6)
I'm not sure if the plan is to pull it, or leave it in the car. A fellow 3SI'er is doing the work. I don't have any issues with the VR-4 currently. My oil pressure is probably a bit low, sits 2 ticks from the bottom at idle. Just trying to knock out as much as possible when the time comes
Old 11-01-2007, 07:45 PM   #6 (permalink)
Pearl White 92 Stealth TT
mike92stealthtt's Avatar
Drives: 100+ IDC's
Trader Rating: (11)
mike92stealthtt Level 2mike92stealthtt Level 2mike92stealthtt Level 2
I would definatley pull the engine if I were you. I did everything on your list minus the rod bearing/main bearings/thrust washers but I did VSS/3rd gen lifters/motor mounts. Since you are doing cam seals you are going to have to pull out the cams which is great for doing 3rd gen lifters but the VSS is still a PITA with the engine in the car. (Check out the group buy section for a great deal on 3rd gen lifters) Pull the engine and whoever is working for you will thank you later.
If you got a 96 stealth wing you want to sell please PM me.
mike92stealthtt is offline   Reply With Quote
Old 11-02-2007, 05:17 AM   #7 (permalink)
Certified Car Nut
JeffWVR4's Avatar
Yeah, that's kinda what I was getting at too. I've done most of that stuff with the engine in the car before, and I swore I'd never do it again without pulling the engine. And I haven't.
Old 11-04-2007, 02:52 AM   #8 (permalink)
Drives: Red 1991 VR-4 (#3)
ZephTheChef Level 1ZephTheChef Level 1
Pulling the engine is what...a 3 hour job with hand tools when you know what you are doing? I don't hardly do ANYTHING without pulling then engine...makes for good practice and a clean job.
"why its a tubloidial butt noid!" - Ray Pampena, 2006
ZephTheChef is offline   Reply With Quote
Old 11-04-2007, 07:13 AM   #9 (permalink)
Drives: 92 VR-4
Zeph do you do all your own work? Have you had any practice replacing the throw out bearing? On start up mine is making some noise. When the clutch is in no more noise. After I drive around for about 5 minutes the noise disappears altogether.
Old 11-05-2007, 02:36 AM   #10 (permalink)
rkesh88 is an unknown quantity at this point
ok well not to thread jack or anything, but im going to buy a 92 VR4 and it has 90k on the clock, and is this something i should be worried about when i get to this service time?
rkesh88 is offline   Reply With Quote
