Go Back   3000GT/Stealth International Message Center > Modifications and Technical Support > Miscellaneous > Body & Paint
Old 05-12-2008, 07:39 PM   #1 (permalink)
suthnyanki's Avatar
Drives: 93 & 95 Stealth Base
suthnyanki is an unknown quantity at this point
Dodge Is side skirt & door panel swap possible?
Anyone know if a 93 RT side skirts and lower door panels can be used on a 95 Stealth base without losing the center molding? Where did they make up the difference for the molding width? On the bottom,top or both of the door panels and fenders?
suthnyanki is offline   Reply With Quote
Old 05-26-2008, 06:45 AM   #2 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (76)
Stealthee Level 7Stealthee Level 7Stealthee Level 7Stealthee Level 7Stealthee Level 7Stealthee Level 7Stealthee Level 7
Default Re: Is side skirt & door panel swap possible?
Yes you can use the side skirts and door panels on a base. However that molding convers the part the lower door panels pop into so it would go away.
