Removing front bumper - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Go Back   3000GT/Stealth International Message Center > Modifications and Technical Support > Miscellaneous > Body & Paint
Old 05-23-2006, 11:26 AM   #1 (permalink)
Civics taste like chicken
Drives: like crazy again
Turbo79 Level 1Turbo79 Level 1
Feedback Score: 18 reviews
Default Removing front bumper
I have a 95 VR4 and I'm getting ready to install a FMIC. Rather than just start taking things apart haphazardly, I'm looking for a little guidance on the process of removing the front bumper. Does anyone have some step by step instructions or advice to offer?
Turbo79 is offline   Reply With Quote Quick reply to this message
Old 05-25-2006, 09:03 PM   #2 (permalink)
This, too, shall pass.
JoshAnker's Avatar
Drives: 95 Stealth
JoshAnker Level 2JoshAnker Level 2JoshAnker Level 2JoshAnker Level 2JoshAnker Level 2
Feedback Score: 31 reviews
Default Re: Removing front bumper
I'll bump/subscribe... we need a walkthrough for this anyway.
JoshAnker is offline   Reply With Quote Quick reply to this message
Old 06-01-2006, 10:11 PM   #3 (permalink)
93V
I'm Back
93V's Avatar
Drives: 94 Supra, 93 VR-4
93V is an unknown quantity at this point
Feedback Score: 23 reviews
same boat...someone direct us
93V is offline   Reply With Quote Quick reply to this message
Old 06-02-2006, 09:18 AM   #4 (permalink)
Tool Man's Avatar
Drives: Twin Turbo 350Z
Tool Man Level 1Tool Man Level 1Tool Man Level 1
Feedback Score: 43 reviews
It's not even worth a write up. There are screws that hold the top of the bumper cover on and screws that hold the bottom on. There are some plastic holders in the fender well as well as one real screw in the well at the top of the bumper. There are screws in the turn signal housing and a few in the headlight housing. There are plastic holders in the "mouth" of the bumper along the top of the opening. It will take around 45 minutes to get off if you haven't done it before, but it's pretty straight forward.
Tool Man is offline   Reply With Quote Quick reply to this message
Old 06-02-2006, 12:57 PM   #5 (permalink)
JoshAnker's Avatar
Drives: 95 Stealth
do we need to remove any fender guards?
Old 06-02-2006, 01:23 PM   #6 (permalink)
Tool Man's Avatar
There are 3 or 4 of the plastic screws in the inner fender gaurd that go into the bumper, and the one screw I was talking about is behind the gaurd. You don't have to take the hole gaurd out though. When you remove the plastic screws, it's enough to get to the one real screw.
Old 06-02-2006, 03:25 PM   #7 (permalink)
For my 95 VR4, I ended up using the manual and it is very straight forward. In brief, from memory:
- remove the active aero (if you have it)
- remove the side lights (one screw and they pop out - disconnect eletrical plug)
- remove headlights (3 bolts on top and one on the side through the sidelight - disconnect electrical plugs (2) )
- remove 2 bolts from where the headlights were sitting on top of the bumper
- remove 3 bolts from the inside of each fender well (taking off the wheel well skirt for easy access - they're pretty high up there)
- remove 7 bolts from right in front of the radiator on top of the bumper
- remove 5 (?) plastic screws from lower air scoop
The bumper should slide straight out.
I think that was pretty much it. I'll check at home tonight and update this post if I see that I missed any major steps
Old 06-02-2006, 09:22 PM   #8 (permalink)
Tool Man's Avatar
I had 8 to 10 bolts on the under side of my bumper. Non active aero, that may be the difference.
Old 06-03-2006, 11:15 AM   #9 (permalink)
JoshAnker's Avatar
Drives: 95 Stealth
headlights & turn sigs must be removed for 2g cars, too?
Old 06-03-2006, 11:29 AM   #10 (permalink)
Tool Man's Avatar
Yes 1234
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
