Go Back   3000GT/Stealth International Message Center > Modifications and Technical Support > Miscellaneous > Body & Paint
Old 08-16-2009, 06:31 PM   #1 (permalink)
marshallh's Avatar
Drives: 1994 3000GT Base
marshallh Level 1marshallh Level 1marshallh Level 1
Feedback Score: 2 reviews
Default Rear bumper project
My back bumper was in crappy shape. The paint was past help, and my friends brother backed into me without me knowing. Left a nice crease in the plastic, and dented the hatch.
So I decided to take it off. Bad choice.
Here is my old man and I working on the top part
I got a few bolts out but most of them sheared right off. Ended up drilling out about 10 bolts and running a tap through. They are all M6-1.00 bolts.
Pretty sad
I guess it was good we took it off, though. Old license plate bracket.
Beyond repair, so I fabbed another one out of galvanized sheet metal.
Getting the crease out was tricky. It's in an area you can't put Bondo on(acutally you want to avoid bondo on plastic period.) Lucky for us, with application of heat it is pliable.
I got a heat gun on the low setting and heated up the backside gradually. Plastic sucks at conducting heat so be careful. I put on a oven mitt and started rubbing on both sides. Eventually after 10 minutes I got the crease blended back in. It's pretty darn good but you can still see a small dimple where it used to be.
Primer.
Single stage acrylic enamel.
Found this guy while I was looking for an air drill
YouTube - mouse in a bucket
Got a 99 garnish.
All in all it was a major pain in the ass, if you just want to paint, then leave things on unless you want a project, or your car has never seen salt.
any questions, ask now before I forget everything
"Being an engineer, I refuse pick the easy option, but rather the one that seems best, which inevitably devolves into a weekend of hacking, cursing, and setting things on fire, with a best case of eventually restoring the object of interest to something resembling a functioning state."
marshallh is online now   Reply With Quote
Old 08-16-2009, 06:34 PM   #2 (permalink)
3/S owner since 2003.
ilian51378's Avatar
Drives: 95' GTO SR ATX
ilian51378 is an unknown quantity at this point
Default Re: Rear bumper project
Good job! Looking good with the 99' garnish...
92' Dodge Stealth ES MTX - 3000GT body conversion, 99' lifters, replaced VSS, valve job done 03/2008, RT sails, RX-7 headlight kit (to replace the pop-ups), 8,000K HIDs. - SOLD!
95' Mitsubishi GTO ATX AWD AWS- 8,000K HIDs, 99' rear garnish, 99' front end, AA spoiler, Saleen wheels.
http://www.cardomain.com/ride/3847604
http://www.cardomain.com/ride/996619
http://www.myspace.com/ilian51378
ilian51378 is offline   Reply With Quote
Old 08-16-2009, 06:45 PM   #3 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3
Feedback Score: 151 reviews
No you don't want to use bondo on a bumper cover, but they do make a flexible resin that does the job.
Old 08-16-2009, 06:46 PM   #4 (permalink)
Wingless
Gen1 3kgt's Avatar
Drives: 92 3000gt SL-TT
Gen1 3kgt is an unknown quantity at this point
Feedback Score: 13 reviews
looks good... not a fan of the '99 garnish though...
:edit: my sarcasm fails because you can barely tell i have a 99 garnish in my sig.. haha
Gen1 3kgt is offline   Reply With Quote
Old 08-16-2009, 07:03 PM   #5 (permalink)
marshallh's Avatar
another pic
stealthee: do you recall the name of that resin? I will have to use some on my front bumper.
Old 08-16-2009, 07:07 PM   #6 (permalink)
Banned
Drives: 92 VR4
byebye_sti Level 2byebye_sti Level 2byebye_sti Level 2byebye_sti Level 2byebye_sti Level 2
Feedback Score: 49 reviews
Doesn't match the rest of the car now.
Nice job!
byebye_sti is offline   Reply With Quote
