Go Back   3000GT/Stealth International Message Center > Modifications and Technical Support > Miscellaneous > Body & Paint
Old 05-28-2008, 05:57 AM   #1 (permalink)
3000 Golf Tengo is an unknown quantity at this point
Default Paintless dent removal or puddy work?
Hey guys. I just started this to maybe get a few opinons on which method people prefer.....paintless, or puddied over and repainted? I have a fair share of minor dents on my car and a major dent with paint missing on my passenger door from soemone opening their door into it. I would like to get these removed soon and would appreciate your comments. Thanks, Drew
3000 Golf Tengo is offline   Reply With Quote
Old 05-28-2008, 06:05 AM   #2 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (61)
Default Re: Paintless dent removal or puddy work?
Not PDR. It'll crack the paint under the clear and you'll get fun little rings of rust in time.
2002 WJ -- 1994 VR-4 -- Canon Rebel XTi
Originally Posted by Kenneth Ellis View Post
Every one of you are fools, each and every one.
Old 05-28-2008, 06:59 AM   #3 (permalink)
Moderator
Lord Warlock's Avatar
Drives: 2004 SVT Cobra,91TT
Trader Rating: (9)
Lord Warlock Level 5Lord Warlock Level 5Lord Warlock Level 5Lord Warlock Level 5Lord Warlock Level 5Lord Warlock Level 5
On panels with multiple dings or dents on it, i'd probably opt for fixing it the old fashioned way, have a body shop bang out the dents and then putty over them and repaint, but panels that only have one or two dings, i'd use paintless dent repair on them. You don't want to just fill in the dings with putty, you want to level the surface first by hammering out the dings properly, then only using a small amount of putty to cover the tool marks in the metal and assist in smoothing the surface out.
91 Stealth TT Stillen Intake, Stillen DP, DN Y Pipe, HKS EVC IV, GReddy BOV, Burlwood Dash kit, New Katzkins, OEM Short Block, RPS Max Street Clutch, Denso 310lph fuel pump, 13G Turbos, Borla exhaust, 550 DR Injectors, HKS SAFC, 2 gauge pod CF A/F gauge, autometer boost gauge. Custom vented blisters, New Valves, rebuilt heads, timing belt, new bearings and pistons. 35k invested.
Other cars: 1969 charger R/T SE, 04 SVT cobra
Lord Warlock is offline   Reply With Quote
