Well... I can tell you where I got the lights. The construction is just an extra mounting bracket I got from a spare headlight set and a couple pieces of angle iron cut from a bed frame with a bolt welded to it. There is no left/right adjustment because of this. There isn't a lot of room to work with.
I used an angle grinder to shape the bed iron before I welded it to the headlight bracket so it would fit down in the headlight well.
BTW: I already know that my welding sux.....so you don't need to remind me.
