Go Back   3000GT/Stealth International Message Center > Modifications and Technical Support > Miscellaneous > Body & Paint
Old 09-19-2009, 03:39 AM   #1 (permalink)
therikoxide's Avatar
Drives: '91 Stealth ES
therikoxide is an unknown quantity at this point
Default Installing 99 Hella Style Fogs on 91 Base
I have no idea how to wire my fogs up to my fuse box so Im hoping I can get some help here
I would like to have them come on with my parking lights and then stay on with headlights both standard and bright.
Any help is greatly appreciated
therikoxide is offline   Reply With Quote
Old 09-30-2009, 03:32 AM   #2 (permalink)
SoCal3s.com
ToeKnee805's Avatar
Drives: Red 1993 3000GT
ToeKnee805 is an unknown quantity at this point
Default Re: Installing 99 Hella Style Fogs on 91 Base
I dont know how to wire them for them to be on as running/low/high beam lights. But I do know how to wire new foglights to a 1st gen harness. What you wanna do is cut your 1st gen foglight plug under your crashbar, and there should be 2 exposed wires. A power and a ground. I dont know which one is which. But get your hella wires and find which are power and which are gorund and try one with one. If that doesnt work, switch em up and that SHOULD work since theres only 2 wires. Then once youre happy enough. Go ahead and solder or crimp them together, add some electrical tape and youre set.
ToeKnee805 is offline   Reply With Quote
