Go Back   3000GT/Stealth International Message Center > Modifications and Technical Support > Miscellaneous > Body & Paint
Old 04-27-2008, 03:31 PM   #1 (permalink)
3KGT2NV's Avatar
Drives: 1994 3kgt vr-4
Trader Rating: (11)
3KGT2NV Level 33KGT2NV Level 33KGT2NV Level 33KGT2NV Level 3
Default Equipment for prepping paint
Howdy all,
Next week im going to be starting my car for paint prep and was wondering what type of equipment I should use.
Is a small orbital hand sander good or should i use something else.
I know about the grits of sand paper that im going to need but don't know what other stuff I should have at hand for this.
Any advise that is helpful is appreciated
Board at work check out these free games
http://s3.gladiatus.us/game/c.php?uid=89364
or
http://astroempires.com
3KGT2NV is offline   Reply With Quote
Old 05-03-2008, 02:49 PM   #2 (permalink)
RTBOOST
Street_Chally73's Avatar
Drives: '91 Stealth R/T TT
Trader Rating: (7)
Street_Chally73 is an unknown quantity at this point
Default Re: Equipment for prepping paint
Though I realize you posted this quite a while ago, I'd suggest getting a DA (dual action) sander as well as an in-line sander. The DA is very useful for getting filler roughed in prior to using a hand sanding board. The in-line sander is great for larger body panels and what not. Another good thing to note is to use a criss-cross pattern when using the sanding board (just in case you didn't know that). Good luck man.
'73 Dodge Challenger 340.............................(X)
'91 Firestorm Red Stealth R/T TT...................(X)
Street_Chally73 is offline   Reply With Quote
Old 05-03-2008, 02:51 PM   #3 (permalink)
3KGT2NV's Avatar
Trader Rating: (11)
thanks due to crap weather I had to put the project off a little bit.
Old 05-03-2008, 06:44 PM   #4 (permalink)
plexy is an unknown quantity at this point
Are you going to do the paintjob yourself? I wouldn't recommend that since you don't have much experience and it's very easy to screw up...If you take it to the bodyshop....MAKE SURE they are TAKING ALL THE SEALS OFF!!! And not just tape them...Cause that's what they usually do...and this is the reason why paint starts peeling off so soon.
AEM EMS, 3.1 L , GT347 turbos, Ross pistons, RPS stage 3 clutch, Fidanza flywheel, 550 CC Denso injectors, Walbro 255 fuel pump, AAM Spec twincone intake, Apex-i GTR intercooler, full HKS IC piping, HKS SSBOV, custom downpipe, custom straight pipe, Apex-i dunk muffler, Greddy Profec B boost controller, Greddy EGT gauge, Greddy turbotimer,intrax springs, 6 point roll cage, carbon fiber hood.
plexy is offline   Reply With Quote
