Old 04-22-2008, 07:06 PM   #11 (permalink)
Cobane's Avatar
Drives: nope, mostly towed
Trader Rating: (6)
Cobane is an unknown quantity at this point
Default Re: Will a FWD trans. hold the power of tt?
my tt swap has eaten three FWD trannys, an axle, the splines inside my spec stage 4 clutch, and a kormex diff....
when going N/A-TT, expect to find weak points in drivetrain.
FWD TT Swap
Cobane is offline   Reply With Quote
Old 05-03-2008, 02:17 PM   #12 (permalink)
Man thats fast
ducky's Avatar
Drives: 92 R/T & 92 R/T TT
ducky is an unknown quantity at this point
Ya even if you don't do a tt swap if you continue to beat on your fwd tranny you will blow your diff and it is only a matter of time. Do a search for "blown Differental" and you will find a ton of people that have issues with blown diff's including myself ;-(. Took 2 years to get myself a replacement tranny and after I got it in and 5 days later spun the bearings. ahhh i'm depressed now.
Originally Posted by Zentelis
I'm so unlucky with cops that as soon as I turn my car on, 3 or 4 pop out of my trunk and give me a ticket
ducky is offline   Reply With Quote
Old 05-04-2008, 09:39 AM   #13 (permalink)
Born In Italy
italiano3kgt's Avatar
Drives: 1993 3000gt N/A
italiano3kgt is an unknown quantity at this point
wow i found it. i need a little bit of help with this also. i did the tt swap 2 weeks ago and it was a 93 tt trans converted to a FWD. im strting to run into some problems here, sometimes when i hit the gas hard in 1st or 2nd after the clutch is engaged it feels like the axles are slipping in the trans. it shakes the whole car about 5-7 time really fast and its really loud, it sound like pops. im so confused of what it could be. here are my mods if that helps.
hks intake, downpipe, bov
stage 4 clutch
please help i dont want to keep driving it if something really bad is going to happen. if you can call so i can explain whats happening a little better that would be great, my name is nick 7578711496.
She love's the way i drive her!!!!
italiano3kgt is offline   Reply With Quote
Old 05-04-2008, 10:34 AM   #14 (permalink)
Gen1 3kgt's Avatar
Drives: 92 3000gt SL-TT
Trader Rating: (10)
Gen1 3kgt is an unknown quantity at this point
is your car a 93? where did you get the axles? are they new?
Gen1 3kgt is offline   Reply With Quote
Old 05-04-2008, 11:00 AM   #15 (permalink)
Born In Italy
they were sent a front clip from japan. and everything had 45k miles on it. they are used. do you think thats the problem?
Old 05-05-2008, 05:31 AM   #16 (permalink)
SOHC you in the FACE
Ondontii's Avatar
Ondontii is an unknown quantity at this point
Is the clutch fine? Could be the clutch chattering. Axles cant slip. They either work...or they break (since they have splines teeth that mate to another surface. If they slipped that means they are broken. That also means your car wouldn't be able to move under its own power.).
That or you are wheel hopping. You didnt describe why you think the axles are slipping.
Brent
1992 Duster -13.9@107.4 - 5psi - 6g72 3.13L "built" SOHC, Precision T67 P-trim, Tial 38mm open dump, 3" downpipe, 20x12x3" evo style intercooler, 7:1 compression, balanced, shot peened rods, heavily ported heads (+40% on flowbench), Ferrea Competition Plus +2 +1 stainless valves, Nielson Vintage 278 duration custom turbo cams, Custom Ram Style short runner intake manifold, Walbro 255hp, 6*47# injectors, +0.096" Forged Venolias, Total Seal chrome gapless top rings, Fidandza Flywheel, Clutchnet 3 puck solid hub, OBX Helical LSD, Zeitronix wideband/EGT/Boost sensors, 100watt DevilsOwn Meth Kit.
1994 Spirit - 13.987@101.89 - 5psi- 6g72 SOHC, K27 Turbo
Ondontii is offline   Reply With Quote
Old 05-05-2008, 10:48 PM   #17 (permalink)
92PearlTT's Avatar
Drives: 91 RT,00 Focus,00 R6
92PearlTT is an unknown quantity at this point
+1 for wheel hop
92PearlTT is offline   Reply With Quote
Old 05-05-2008, 11:00 PM   #18 (permalink)
SOHC Power!!!
SOHC3000GT's Avatar
Drives: Like a nut job......
Trader Rating: (88)
SOHC3000GT Level 3SOHC3000GT Level 3SOHC3000GT Level 3SOHC3000GT Level 3
stage 4 clutch
That would be wheel hop. I had that pretty bad on my '93...maximals solid motor mounts fixed most of it.
'93 Green 3000GT - under the knife since 11/18/07
like a tampon thief i had to pull some strings
SOHC3000GT is offline   Reply With Quote
Old 05-06-2008, 01:45 AM   #19 (permalink)
Ondontii's Avatar
From the PM he sent me, he likely has a clutch problem too (it has gotten worse).
