Originally Posted by Fast3KGT
hey guys I kno that this particular topic may have already been started before (although i have looked ) and i feel kinda dumb asking it but I have a 98 3000GT SL auto that ive found a 5sp transfer case and a line on getting a tranny for. What other parts will I need to complete the swap?
thanks for your help
you found a 5speed transfer case? Those are for AWD cars. Your car is front wheel drive. You should get a FWD 5-speed trans. You will need the transmission, Clutch set, Flywheel, Slave and master cylinders, hard line for running the fluid, Clutch/break pedal assembly, shifter cables and mounts, Shifter plate and assembly, shift boot, shift knob, passanger and driver side half shafts. I have all those parts if you are interested. Clutch and flywheel are brand new.
