Old 04-03-2008, 11:18 AM   #1 (permalink)
Drives: 1995 3000GT base
Rollypolie is an unknown quantity at this point
Default Transmission shifting problems
I just bought a 1995 3000gt base with a transmission problem i was aware of. The car has an automatic transmission and goes through all 4 gears, but when i press the overdrive button on the car just revs when i give it gas. My mechanic hooked up a snap-on tranny tool to check for problems and said the switch was working properly. Is this a common problem with these cars and could it be an internal problem?
Rollypolie is offline   Reply With Quote
Old 04-03-2008, 11:24 AM   #2 (permalink)
We were all newbs once...
PSnewbie's Avatar
Drives: Stealth SOHC
PSnewbie Level 3PSnewbie Level 3PSnewbie Level 3PSnewbie Level 3
Default Re: Transmission shifting problems
Actually, mines doing something like that. She drives fine w/ O/D off, but as soon as I turn my O/D on she slips like a mofo. I think my clutches are shot.
PSnewbie is offline   Reply With Quote
Old 04-03-2008, 11:54 AM   #3 (permalink)
Yea no one can figure out what the problem is. My mechanic said a tranny flush and maybe changing the filter might fix it but I don't think it will at all, it just doesn't seem logical. I don't want to have to pay someone to rip the tranny out and diagnose the problem so if anyone could help it would be greatly appreciated. Thanks
Old 04-15-2008, 11:09 AM   #4 (permalink)
beatz3kgt's Avatar
Drives: '93 3000GT
beatz3kgt is an unknown quantity at this point
Rolly whats the status of your tranny?
1993 3000GT Base ATX
K&N FIPK - Polished Intake Pipe - Custom Exhaust - Top Line Engineering Ground Wire Kit - IPT A/T Boost Controller - Pioneer Speakers all around - Sony XPLOD - Datalogger
Things To Come
Downpipe - High Flow Cat - Lightweight Crank Pulley - Repaint - 17's - Eibach Lowering Kit - MSD 8.5 Super Conductor Wires - Plugs
beatz3kgt is offline   Reply With Quote
Old 04-18-2008, 08:30 PM   #5 (permalink)
I ordered and End Clutch from IPT and hopefully I;m going to put it in tomorrow if it's a nice day. I'll let you guys know if it fixed my problem. Thanks for all your help I found the diagnosis in another thread here ATX Going into neutral instead of O/D ideas?
