Old 08-26-2009, 11:18 PM   #1 (permalink)
Woefully Optimistic
KingA's Avatar
Drives: 1995 3000GT
KingA is an unknown quantity at this point
Default Transmission Rebuild Experiences?
Clutch is starting to slip pretty bad. I'm going to check tomorrow to see if it's the pedal that needs adjusting. If not, I'm going to bite the bullet and shop around prices for a rebuild, first at the stealership, then local shops. What have you paid in the past? Would you recommend buying a clutch kit from an outside retailer (3SX, IPS, etc) and giving it to a shop to install as opposed to letting them order the parts? OEM or aftermarket? Thanks in advance.
KingA is offline   Reply With Quote
