Old 04-20-2008, 06:14 PM   #11 (permalink)
Drives: 1994 3000Gt N/A
Androcephalous is an unknown quantity at this point
Default Re: MY quest for 5 speed
I finished this swap last week. You actually dont need to leave in the TCU. I was worried i would have to but luckily nothing else runs through it. Easy enough. This thing took me forever but i really only worked on it for like 7 days. seriously if your thinking about doing a 5 speed swap do it. When i took the car down the road it felt muuuuch faster.
Androcephalous is offline   Reply With Quote
Old 04-23-2008, 09:31 AM   #12 (permalink)
l_aysan is an unknown quantity at this point
im in the middle of this mission right now (same reason ... shavings in the ATF, and my diff is leaking because my axels can be moved up and down about 1/8 of an inch)
and i got a donor car for free!
what wiring mods did you have to do?
what i mean is
1. reverse light wiring (did you need to change the plug/where is it on the auto?)
2. clutch depression switch
3. anything else?
Thanks
l_aysan is offline   Reply With Quote
Old 04-23-2008, 11:48 AM   #13 (permalink)
The reverse lights are a pain. If im right on a manual they are on the shifter and an ATX they are on the tranny. Im trying to build a little push switch so when the shifter is in place it hits it. The biggest thing is this peice you have to leave plugged in for the car to even start... ill take a picture of it later. I beleive it was bolted on the auto tranny and the shifter went through it. Basically tells the car its in park. I might take a look at the donor car to see if there is something from the reverse lights in there.... otherwise like i said im just gonna rig up something. HAvent worried about it yet though. Im just happy to be back on the road
Old 04-23-2008, 07:58 PM   #14 (permalink)
i know that the reverse lights switch on the ATX and the MTX are both on the trans (or inside ... hooked up to god knows what plug on the ATX)
the MTX only has one plug on it ... which is definetly the reverse switch. i have both electrical and the chassis manuals so finding out which one it is on the ATX shouldnt be a problem.
do you know if the ECU/TCU changes anything when you shift out of park? such as fuel mixture, or the idle control or anything else? or can i just leave all the plugs that go to the trans without any problems?
thanks again
-Luke
Old 04-24-2008, 01:31 PM   #15 (permalink)
Drives: Stealth, 3000gt VR4
StealthMe is an unknown quantity at this point
I am also at the reverse lights switch problem. I don't have the manuals or schematics so if you find out please let us know!!
StealthMe is offline   Reply With Quote
Old 04-24-2008, 03:13 PM   #16 (permalink)
GTO refurber
Colt45_GTO's Avatar
Drives: like i stole it
Colt45_GTO Level 1Colt45_GTO Level 1
reverse light switch is on the tranny inch up to the right of the filler plug!
Colt45_GTO
Semper Fidelis
Old 04-24-2008, 05:36 PM   #17 (permalink)
i know where the switch is on the tranny but where is the plug on the wiring harness since it's an atx wiring harness
Old 04-24-2008, 09:03 PM   #18 (permalink)
Hes right i got my CD today and the plug is on the tranny..... So far ive left my tcu unplugged and had no problems... everything seems normal.
Old 04-24-2008, 09:20 PM   #19 (permalink)
AhAMaY115's Avatar
AhAMaY115 is an unknown quantity at this point
i know it was explained in great detail on the speedfreakracing.net website, but the site seems to be down or something.....does anyone know what happened???
AhAMaY115 is offline   Reply With Quote
Old 04-24-2008, 11:29 PM   #20 (permalink)
Yes everything works fine yet the reverse lights are not working still. yeah the site does not work any more.
