input shaft oil seal replacement - 3000GT/Stealth International Message Center
Old 01-09-2011, 03:11 PM   #1 (permalink)
PearlR/T is an unknown quantity at this point
Feedback Score: 22 reviews
Default input shaft oil seal replacement
Just pulled my tranny ('91 FWD 5spd) because it's leaking gear oil everywhere from inside the bellhousing. I have a new input shaft oil seal as I believe this is the only place the oil can be coming from. I was hoping I would be able to get to it and replace it myself but it looks like the bellhousing has to be seperated from the tranny. Is this the case?
Thanks,
Brandon
PearlR/T is offline   Reply With Quote Quick reply to this message
Old 01-09-2011, 06:48 PM   #2 (permalink)
Resident Street Racer
NOMIEZVR-4's Avatar
NOMIEZVR-4 Level 1NOMIEZVR-4 Level 1NOMIEZVR-4 Level 1
Feedback Score: 13 reviews
Default Re: input shaft oil seal replacement
yes, the bellhousing needs to be seperated. it is not too hard to do, takes about ten minutes to seperate the two. There is a bearing that needs to be pressed out then you can change the seal.
96 Cianci Widebody 3000GT VR-4
R.I.P. Totalled January 2016
1995 Widebody 3000GT VR-4
NOMIEZVR-4 is offline   Reply With Quote Quick reply to this message
Old 01-10-2011, 11:31 PM   #3 (permalink)
CHRIS75's Avatar
Drives: 93 3000GT VR-QUATTRO
CHRIS75 is an unknown quantity at this point
Feedback Score: 25 reviews
How hard is to take that bearing out? you need any special tools ?
Originally Posted by blizzy View Post
he was probably used to driving his civic and he punched 2nd hahahahaha
CHRIS75 is offline   Reply With Quote Quick reply to this message
Old 01-11-2011, 09:30 AM   #4 (permalink)
NOMIEZVR-4's Avatar
you will need a press.
Old 01-11-2011, 02:04 PM   #5 (permalink)
CHRIS75's Avatar
Hey Brandon where did you get the new seal? is it an oem ?
I also need to get a new input shaft seal but it's for my 93 TT, anybody know a part number ?
Old 01-11-2011, 05:39 PM   #6 (permalink)
I got my OEM seal from 3SX. Not sure if it's the same for all or not. Ended up taking the tranny to a shop. Opening a transmission scares me.
Old 02-22-2012, 06:37 PM   #7 (permalink)
Texan94SL's Avatar
Drives: 94 Pearl White SL
Texan94SL is an unknown quantity at this point
Feedback Score: 20 reviews
Bringing this thread back to life.
I have the same issue. First I thought I had a rear main seal leak but it is gear oil leaking out. I added a UV dye to the gear oil and it glows where the bell housing and block meet. So....it has to be the input shaft seal.
What is a fair price to pay a transmission shop to change this seal if I take them the OEM seal and transmission (removed from the car)?
Also, should I have them replace the bearing that comes out.
Part numbers of the bearing and input seal please.
For a 94 FWD 5 speed.
Texan94SL is offline   Reply With Quote Quick reply to this message
Old 02-22-2012, 09:15 PM   #8 (permalink)
3S Surgeon
jstarr427's Avatar
Drives: '91 VR4
jstarr427 Level 1jstarr427 Level 1
Feedback Score: 8 reviews
When I did mine didn't need any presses, just take it all apart, replace that seal and put it all back together.
Build dates 1991.08.2 and up is MD741818. You're welcome :P
'98 Base Caracas Red 1 of 6: Purchased 3/08, Sold 11/11. Purchased back 9/13: Sold AGAIN 11/13
'91 VR4 Jamaican Blue 1 of 12: Purchased 10/11: BPU+
'99 Audi A6 2.8 Quattro -$1600: Gift to the Fiance
ÜberClean Black on Black '04 Audi A6 2.7T Quattro Rare 6MT, Sport package
I do 3S work locally! PM me for more info.
jstarr427 is offline   Reply With Quote Quick reply to this message
Old 02-22-2012, 09:34 PM   #9 (permalink)
Texan94SL's Avatar
Thanks.
When you say take it all apart....pretty much everything in the transmission has to come out?
Or
Can just the input shaft be removed to make the fix?
I've done internal engine repair on other cars but never opened up a transmission of any kind so I worry most about lifting something out, having parts fall, and not knowing how it goes back together.
Old 02-12-2016, 12:35 PM   #10 (permalink)
Killer99's Avatar
Killer99 is an unknown quantity at this point
Feedback Score: 0 reviews
Default
I have the same problem. Im gonna wing it and try it myself, is there anything I have to worry about falling out and loosing when I separate the Bell housing?
Killer99 is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
