Old 09-17-2007, 06:47 PM   #1 (permalink)
Palais's Avatar
Drives: Stealth RT,68 camaro
Trader Rating: (6)
Palais is an unknown quantity at this point
Default ECS problem
HI,
I just purchased a 92 Stealth RT and I have a problem. When I push the ECS button nothing happens. The tour or sport lights do not come on in the dash. I took out the ECS computer and checked it but I didn't see any leaking capasitors. Any other suggestions on what the problem could be and how to fix it. Thanks so much.
Palais is offline   Reply With Quote
Old 12-13-2007, 11:02 AM   #2 (permalink)
Palais's Avatar
Trader Rating: (6)
Default Re: ECS problem
I also checked the top of the struts in the front and all of the wires look good. Is there a fuse that could be bad or someting since the lights down come on in the dash at all?
Old 02-07-2008, 12:08 PM   #3 (permalink)
Palais's Avatar
Trader Rating: (6)
bump...
Old 02-07-2008, 12:27 PM   #4 (permalink)
S318008 3^07 1
tha92Boostguy's Avatar
Drives: Red 92 Vr4
Trader Rating: (6)
tha92Boostguy is an unknown quantity at this point
Did it just happened or has it been like this for a while?
For all you know the lights in the dash could of burned out. Try this: find somewhere quiet and push the ECS button to see if you can hear it change from sport to tour.
I know mine work (i can hear it) but i am just to lazy to change the burned out bulb (the sport light still works ).They have them at checker auto parts.
An idea that is not dangerous is unworthy of being called an idea at all. -Wilde
tha92Boostguy is online now   Reply With Quote
Old 02-07-2008, 12:58 PM   #5 (permalink)
Moderator
Lord Warlock's Avatar
Drives: 2004 SVT Cobra,91TT
Trader Rating: (9)
Lord Warlock Level 4Lord Warlock Level 4Lord Warlock Level 4Lord Warlock Level 4Lord Warlock Level 4
More than likely the ECS lights came on and someone just removed the bulb from the dash to keep from getting reminded there was something wrong...(it usually defaults to sport) and sold it without replacing the bulb. I've heard people say remove the bulb way too many times here. Instead of just fixing what the real problem was to start with.
Lord Warlock is offline   Reply With Quote
Old 02-07-2008, 01:15 PM   #6 (permalink)
Palais's Avatar
Trader Rating: (6)
I am not sure, I bought the car with it like that. Is there an easy way to tell if the bulb had been removed?
Old 02-07-2008, 01:16 PM   #7 (permalink)
Palais's Avatar
Trader Rating: (6)
haha, this may sound dumb, but do you have to have the car started for the ECS to work, or just have the car turned on?
Old 02-07-2008, 01:55 PM   #8 (permalink)
S318008 3^07 1
Drives: Red 92 Vr4
Trader Rating: (6)
Just pull the bezel its easy. One thing I found out is if you do this the risk of the SRS light to come on is possible. This happens when changing the gauges or anything that has to do with taking this piece off. Don't worry nothing is wrong its just something that happens.
What worked for me is that i kept my door closed when i took it out and then steped out of the car. Unfortunatly i was in a hurry and opened my door while i was installing it (back and forth) and then i turned on. Just take the lightbulb out and its gone. Also for the 1st gen turning the key 5-10 times does the trick....sometimes
http://www.stealth316.com/2-dashpanel.htm <----Check step #6
Just turn the key enough to get the radio going. Then lisen for it.
Old 02-07-2008, 05:05 PM   #9 (permalink)
Moderator
Trader Rating: (9)
I could never hear my ECS work, i could hear the active exhaust motor run but not the ecs, but i can't hear alot of little squeeks that the wife hears.
Old 02-07-2008, 05:16 PM   #10 (permalink)
S318008 3^07 1
Drives: Red 92 Vr4
Trader Rating: (6)
... I have only been married for 1.5 years so my ears still work fine. I figure once I have a kid the hearing loss will begin.
