Old 02-07-2008, 05:55 PM   #11 (permalink)
Palais's Avatar
Drives: Stealth RT,68 camaro
Trader Rating: (6)
Palais is an unknown quantity at this point
Default Re: ECS problem
haha, well I am not married, and don't have any children and when I went out I couldn't hear a thing when I pushed the ECS button. I tried just turning the car on and pushing the button and nothing, no lights that say tour or sport on the dash and nothing that sounds like a motor kicking on. I decided to start the car and see if there was anything different and it was the same deal.....Any suggestions?
Palais is offline   Reply With Quote
Old 02-07-2008, 06:36 PM   #12 (permalink)
Moderator
Lord Warlock's Avatar
Drives: 2004 SVT Cobra,91TT
Trader Rating: (9)
Lord Warlock Level 4Lord Warlock Level 4Lord Warlock Level 4Lord Warlock Level 4Lord Warlock Level 4
try driving it and touching the button, and drive over a manhole cover, in tour you won't feel it much, in sport you'll be able to read the writing on the plate in braile on your ass.
Lord Warlock is offline   Reply With Quote
Old 02-07-2008, 06:39 PM   #13 (permalink)
Moderator
Trader Rating: (9)
If the car doesn't soften the suspension noticeably, its likely stuck in sport as a flashing light would indicate. One of the more common ways for the ecs to stop working is when someone leans on one of the shock towers in the engine bay. Its real easy to do...almost everyone automatically puts their hand on one when reaching over the motor. Leaning on it can cause old brittle wires to crack and stop working. Getting new caps is the cheap solution, replacing struts is the expensive solution.
Old 02-07-2008, 09:57 PM   #14 (permalink)
est. sept, 2000
91vr4n00maxima's Avatar
Drives: slow 97 VR4
Trader Rating: (14)
91vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 7
i could hear my ecs working with the key on/engine off only if i was parked next to a wall.
97 VR4 12.417@111.16 9b time. whats next?
95 mark viii. stock 14.56best ET 98 mph best trap
03 cobra vert. 4 mods=118mph traps
91 stealth TT. td05 18G and everything else.
91vr4n00maxima is offline   Reply With Quote
Old 02-08-2008, 06:16 AM   #15 (permalink)
Palais's Avatar
Trader Rating: (6)
I popped the covers off the top of the struts and all of the wires looked to be in pretty good shape. Its just strange how the tour or sport mode lights don'e come on at all...
Old 02-08-2008, 08:02 AM   #16 (permalink)
Moderator
Trader Rating: (9)
You may want to test each connector and wire to make sure current goes thru each connection, even though the wires look good they could still be cracked inside the insulation, heat and time have a way with old wires.
Old 02-08-2008, 09:03 AM   #17 (permalink)
Palais's Avatar
Trader Rating: (6)
which wires on the top of the struts should have power to them?
Old 02-08-2008, 06:15 PM   #18 (permalink)
Moderator
Trader Rating: (9)
not sure myself, i'm a moron with a multi-meter. But replacing my caps didn't fix my own, but i know when they went bad, and it was when the blisters were off the car and i was playing paintshop.
Old 02-09-2008, 08:27 PM   #19 (permalink)
Palais's Avatar
Trader Rating: (6)
haha, that happens some...i guess I will go out with a multi-meter and see what I can come up with, or if one side has power to one that the other side doesn't...maybe i will find something strange and be able to fix it.
Old 05-07-2008, 08:50 AM   #20 (permalink)
shturts is an unknown quantity at this point
I have recently purchased a 1992 Dodge Stealth R/T and I am having an issue with my ECS. On the dash it says sport mode with a steady green. But when I push the ECS button, nothing happens. Th dash doesn't change nothing. It just stays the same. Any thaughts. All help would be appreciated.
shturts is offline   Reply With Quote
