Old 04-04-2008, 11:49 AM   #11 (permalink)
Member #0711
defgh1's Avatar
Drives: 99 VR4, 04Volvo V70R
Trader Rating: (7)
defgh1 is an unknown quantity at this point
Default Re: Driveshaft Problems
Originally Posted by Apache View Post
http://www.supercar-engineering.com/.../Mods/TT/CFDS/
Erik Gross was one of the first to document the vibration problems with the 2-Piece setup. As I said before though, PST has since fixed this problem (at least to my knowledge).
And thanks for the info on the one-piece system. But does there seem to be a trend to the vibrations? (ie. 5-Speed or 6-Speed, build-date, brackets or braces on the transfer case, aftermarket rear LSD) I'd like to get the 1-piece since that would obviously be lighter and put more power through to the wheels, but I'm not going that route if it'll just end up killing my car.
I am not aware of specific trends for vibration. I suggest you call PST at 727-442-1711 and talk to Mark. He appears to be upfront about any possible problems. Also, if you do have any problems with a 1 piece they will upgrade it to a 2 piece for just the cost difference between the shafts.
Doug H
91 Sandstorm TT, 431 AWHP, 433 ft-lbs. , Kormex 25 spline,LSD, RPS CC Clutch, 4 bolt conversion, Super 15Gs, Stage 3 heads, DSM Sidemounts, PST Driveshaft, Blitz DSBS, HKS Exhaust, 3SX Downpipe, Supra Pump, 780 cc PTE Injectors, SX Fuel reg. & dual feed, AEM, Duel WJO Wideband, HKS DL1, Alcohol Injection. Photos: -->
defgh1 is online now   Reply With Quote
Old 04-29-2008, 09:29 PM   #12 (permalink)
cRuff's Avatar
Drives: VR4 1992
cRuff is an unknown quantity at this point
PST a/CF driveshaft on s3x is not even 1grand, thats a great deal the 2 piece. corect me if im wrong but saving about 12 pounds on a new driveshaft will help save the life on the tranny and transfercase. 12 lbs is a big difference for a tcase.
cRuff is offline   Reply With Quote
