Old 01-31-2009, 05:16 PM   #71 (permalink)
Gear Head
Bret Brinkmann's Avatar
Drives: Rear wheels only...
Bret Brinkmann Level 1Bret Brinkmann Level 1
Default Re: Don't weld the AWD VCU
There are two different parts you can weld to achieve 2WD. The VCU or the planetary gear assembly. The planetary gears are a stronger way to go but a welded VCU can work too. I have seen the welded VCUs crack along the welds, even with a good welder it can happen on higher HP cars. I do not know the exact limit for a welded VCU but a welded planetary assembly has to yet to even crack on T4's 995 AWHP. The VCUs would crack when T2 was putting down 600 FWHP.
I personally welded the planetaries when I switched to RWD and have had no issues with it. But either way you go you don't have to remove the silicon from it. The silicon goo leaks past the seals when the VCU over heats from being over worked. When you weld either the planetaries or the VCU the VCU can not work so it is not a problem. The main problem is making sure that your welder is good.
If you switch to FWD I do recommend that you remove the output shaft and get one of the plugs for the hole. Those plugs are a lot less likely to leak than the output shaft seals. Plus you get ride of a few pound of dead spinning weight.
The thing you need to worry about as far as VCU types is weather you have an 18 spline tranny or a 25 spline tranny. You can not go by the year any more because so many of these cars have had a tranny swap and god know what was put into it. I have even seen cars that should be 25 spline and instead they are 18.
250 RWHP
Old 07-22-2009, 05:08 PM   #72 (permalink)
3Si Co-Founder
SUTHNR's Avatar
Drives: Everywhere
Trader Rating: (9)
SUTHNR is an unknown quantity at this point
For those that may not be aware. 3SX offers both the reqisite plug for pulling out the output shaft to convert the AWD gaearbox to FWD:
Transmission AWD-to-FWD Conversion Plug*-*Mitsubishi 3000GT*/*Dodge Stealth
And for the AWD guys with burnt VCUs, we also now have good remanufactured ones that are holding up very well so far:
VCU Viscous Coupling Unit - 3000GT Stealth AWD*-*Mitsubishi 3000GT*/*Dodge Stealth
EricB
Eric "SUTHNR" Bowden's Garage (click to visit)
* 1993 Dodge Stealth R/T
The 222 HP Stereo... The most modified slowest naturally aspirated FWD Stealth out there.
* 2008 Toyota Tundra Pick'm'up Truck
Mods: Right Foot FTW!
* 2005 Chrysler PT Cruiser Convertible High Output Turbo
Mods: The Wife FTW!
* My stereo site lives here: The 222 HP Stereo...
* My personal venture:
Edgy Elegance Photography - Weddings, Home Sales, Automotive, etc!
* I love taking and creating Panorama Pictures: Check out my Panorama Gallery
* The 3000GT/Stealth Collectibles Site: Ultimate 3S Collectibles Archive
* Visit 3SX for record setting parts at www.3SX.com
NG09 Pics LOADED!
3SX 1/4 Mile Times
3SX T2 FWD 3S 10.19 @ 140.31
3SX T4 AWD 3S 9.214 @ 154.98
Also T4 AWD 3S 9.339 @ 159.23
3SX twitter | 3SX FaceBook
SUTHNR is offline   Reply With Quote
Old 07-23-2009, 12:54 PM   #73 (permalink)
15t's ... ? yep
DigiiManDan3KGT's Avatar
Drives: 80Gig WesternDigital
Trader Rating: (7)
DigiiManDan3KGT is an unknown quantity at this point
Originally Posted by DigiiManDan3KGT View Post
No I'm unique to this situation because I took an AWD Getrag and converted it to FWD by Welding Solid My VCU and removing the Output Shaft that goes to the Rear end.
Other FWD cars that buy a AWD getrag need to remoe their VCU and weld it up. I would trade them straight up for their good VCU. I'd be giving them a Properly welded FWD VCU. They would not need to worry about all the work that is involved with removing the Scilicon via blow torch and then welding all the spider gears. Its alot of work that people dont have the tools to do.
I have 91 awd vcu welded & 92 awd vcu welded. They are different with the space between the teeth. Both have been tested in FWD 350hp cars.
I was wrong about my 92 VCU it was a 93 and after further inspection they appear to be the same.
Green 1995 3000GT // 15t Turbos // ATX to MTX // NA to TT // FWD to AWD // Purchased 11/12/02
White 1999 3000GT Black Dash/Tan Leather Interior // SOHC // MTX // Stock Daily Driver Purchased 7/25/07
<-- Click Here Join FL3S
DigiiManDan3KGT is offline   Reply With Quote
Old 07-23-2009, 01:07 PM   #74 (permalink)
NG09 Associate Sponsor
Venom13132's Avatar
Drives: Small Car Big Engine
Trader Rating: (109)
Venom13132 Level 1Venom13132 Level 1
I believe all 93's are 25 spline and some 92's have the 25 spline also, but most 92's are 18 spline.
Venom13132 is offline   Reply With Quote
