Originally Posted by gilrod7
Thanks I didn't know, now I know. So everyone that wants to convert their front wheel drive 3s/stealth to awd has to get that part from a part out 3s/stealth or what? Can you order from the dealer?
No I'm unique to this situation because I took an AWD Getrag and converted it to FWD by Welding Solid My VCU and removing the Output Shaft that goes to the Rear end.
Other FWD cars that buy a AWD getrag need to remoe their VCU and weld it up. I would trade them straight up for their good VCU. I'd be giving them a Properly welded FWD VCU. They would not need to worry about all the work that is involved with removing the Scilicon via blow torch and then welding all the spider gears. Its alot of work that people dont have the tools to do.
I have 91 awd vcu welded & 92 awd vcu welded. They are different with the space between the teeth. Both have been tested in FWD 350hp cars.
