Old 11-01-2004, 04:30 PM   #41 (permalink)
3000GT SL TT
sipe16's Avatar
Drives: 95 VR-4 & 94 Base TT
sipe16 is an unknown quantity at this point
Default Re: Don't weld the AWD VCU
Originally Posted by MilkyClr69
Just need a quick question answered, hopefully i can help an AWD guy in the process and save my broke-ass a buck or two...
I have a 92 18 spline tranny and i'm converting it to fwd via welding the vcu. So I'd rather trade it for a AWD guys bad vcu and help him out and make a buck for myself. What VCU's will fit into MY tranny to weld, and what trannies will MY VCU fit into so i can trade it to someone.
I read most this thread but i just got confused...heh.
You would be better off just swapping between any 18 spline transmission if some of this is confusing. Otherwise you'll end up swapping other guts such as the sun gear and pinion shaft, as stated above. I'll also tell you that it's a little hard to find someone to swap with, i tried for several weeks. Just weld the planetary gears together/to the carrier as bret had said, I did this with the transmission i just put in my car vs. welding the vcu, thought i'd give it a try
Black 1994 3000GT Base:
TT Conversion, VR-4 6spd tranny swap, stillen DP (only), gutted rear precat, Autometer A/F guage, Defi-D EGT Guage, Defi-D Boost guage, VR-4 ECU, All 4 Poly Mounts, SS Braided Turbo Oil & Water Feed/Return lines, Greddy E-Manage, E-Manage Cable & Software, Crossdrilled & Slotted Rotors, Raybestos STS Ceramic Brake Pads, Full head port & polish (by a reputable race engine builder in the area), SPEC Stage 2 AWD clutch, Radius Valvegrind, Clevite 77 Bearings
Next To Come:
Greddy Profec e01, Apex'i Turbo Timer, Custom Direct Port Propane Injection
Black 1995 3000GT VR-4:
Supra Fuel Pump, Custom Catback Exhaust, Gutted Precats, Unorthodox UD Pulley, RPS MAX 6 Puck Sprung Hub, td04/13t's, Lightweight Alcohol Injection Kit, Blitz SBC i-Color Boost Controller, DeftRacing 5se7en5 Hood, '99-Style Lifters, Greddy E-Manage (blue), 550cc Injectors, Greddy Turbo Timer
sipe16 is offline   Reply With Quote
Old 11-02-2004, 01:15 AM   #42 (permalink)
MilkyClr69's Avatar
Trader Rating: (13)
MilkyClr69 is an unknown quantity at this point
Well i mean i could just weld the VCU I have but i figured if i could help out the community in the process i would.
So you welded the planetary gears, hows that working for you?
96 SL
MagnaFlow Catback, K&N Intake, 18 x 8 ADR Sterling, 245 40 18 Ecsta Supra, Limo/15% window tint, Cross-drilled and slotted rotors, 12" sealed IDMAX w/ 1000 Watt Hifonics amp. Infinity & JBL speakers powered by Hinfonics amp, Alpine 7893.
TT engine/tranny swap
Fixing a few problems and she'll be back on the road!
MilkyClr69 is offline   Reply With Quote
Old 11-02-2004, 01:17 AM   #43 (permalink)
3000GT SL TT
sipe16's Avatar
not sure yet havn't driven it. Bret is the one who suggested it. He's running that in his rwd, and he's trying to break it - hasn't succeeded that i know of. thought i'd give it a try
Old 11-03-2004, 02:49 PM   #44 (permalink)
Gear Head
Bret Brinkmann's Avatar
Drives: Rear wheels only...
Bret Brinkmann Level 1Bret Brinkmann Level 1
Just to clearify how bad I am beating the crap out of my car check out the RWD VR4 thread for the newly post NOPI burnout video. I started that burn out in 2nd gear with a 7 K clutch dump.... Deffinatly NOT the first time I have done a 2nd gear 7K clutch dump.
250 RWHP
Old 11-03-2004, 06:24 PM   #45 (permalink)
<T>
What have we here
<T>'s Avatar
Drives: a cash vacuum
<T> is an unknown quantity at this point
just think of it a QA testing
On slight hiatus again, bad timing...
<T> is offline   Reply With Quote
Old 11-22-2004, 10:37 AM   #46 (permalink)
3/S Guru
Drives: 90 Buick Century
Trader Rating: (8)
A/V dude is an unknown quantity at this point
Anyone have any input to this thread??
http://www.3si.org/forum/showthread.php?t=243845
A/V dude is offline   Reply With Quote
Old 05-13-2005, 02:12 PM   #47 (permalink)
Certified Car Nut
JeffWVR4's Avatar
Drives: Like a Grandpa
JeffWVR4 is an unknown quantity at this point
OK. So hopefully none of you guys are welding up good VCU's anymore . So given that, does anyone have a good working VCU that they'd want to trade for one that's not plus a little cash?
Jeff W.
www.xpauto.net
Red '92 VR4 226,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, 1/4 mile at a time, the rest was easy
Big 16G Turbos w/IPS headers and pre-cat eliminators, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, DR Fuel Pump Hotwire Kit, South Bend FE/SS Stage 5 clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, PowerStop/Stillin rotors, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi wheels, 2-tone all-leather Interior.
JeffWVR4 is offline   Reply With Quote
Old 05-21-2005, 09:25 AM   #48 (permalink)
2 of 3 in the US!
ES 3000TT's Avatar
Drives: ON 2x SIDES
Trader Rating: (27)
ES 3000TT is an unknown quantity at this point
PM me bro! got a couple
ES 3000TT
RHD
2 of 3 in the US!
ES 3000TT is offline   Reply With Quote
Old 06-13-2005, 10:21 PM   #49 (permalink)
15t's ... ? yep
DigiiManDan3KGT's Avatar
Drives: 80Gig WesternDigital
Trader Rating: (7)
DigiiManDan3KGT is an unknown quantity at this point
hes got mine! Thief! j/k Jean has it!
Green 1995 3000GT // 15t Turbos // ATX to MTX // NA to TT // FWD to AWD // Purchased 11/12/02
White 1999 3000GT Black Dash/Tan Leather Interior // SOHC // MTX // Stock Daily Driver Purchased 7/25/07
<-- Click Here Join FL3S
DigiiManDan3KGT is offline   Reply With Quote
Old 06-13-2005, 10:59 PM   #50 (permalink)
Certified Car Nut
JeffWVR4's Avatar
Apparently not any more. Anybody else?
