Clutch Pedal Stuck To The Floor.... - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 02-15-2010, 04:50 PM   #1 (permalink)
Drives: Elvis around Memphis
Flash Gordon is an unknown quantity at this point
Feedback Score: 5 reviews
Thumbs down Clutch Pedal Stuck To The Floor....
I hope this is the right section. I was looking for the "I'm Fucked Again Section" but had no luck
1994 Stealth sohc fwd:
So I'm coming home from work sitting at a red light. Light turns green, I go to hit the clutch ,but its already stuck to the floor...WTF
I can pull the pedal up with my hand but it fails as soon as you put your foot on it...0 pressure
Any Ideas/
Thank You,
Flash
UPDATE:
I just went to pull my car home. When I got there I filled my clutch fluid and cranked the car heard a noise and looked under the car and found the fluid I had just put in on the concrete
Could this be the slave valve that could've failed?
Flash Gordon is offline   Reply With Quote Quick reply to this message
Old 02-15-2010, 04:54 PM   #2 (permalink)
Minnesota 3/S
chevelle5434's Avatar
Drives: 95 RT TT
chevelle5434 is an unknown quantity at this point
Feedback Score: 13 reviews
Default Re: Clutch Pedal Stuck To The Floor....
Sounds like you have a bad master of slave cylinder. Look at the clutch fluid resorvoir and see if there is any fluid in there.
chevelle5434 is offline   Reply With Quote Quick reply to this message
Old 02-15-2010, 05:00 PM   #3 (permalink)
BrianWSNC Level 1BrianWSNC Level 1
Feedback Score: 0 reviews
I bet your slave cylinder is leaking, and all your fluid has leaked out. Refill it and check for leaking at the slave cylinder boot. just replace it, bleed it and your good to go
BrianWSNC is offline   Reply With Quote Quick reply to this message
Old 02-15-2010, 05:02 PM   #4 (permalink)
Flash, don't think your "fucked" again. These cars are getting old and parts wear out.
If you want something that is less likely to have something break, buy a new car.
5k vs 30k dollars.. for a 40 dollar slave cylinder and aggravation to things breaking vs 25 Thousand dollar diff...
you got to pay one way or the other
Old 02-15-2010, 06:32 PM   #5 (permalink)
95SL_2501 is an unknown quantity at this point
This just happened to me,and it was the slave cylinder. Also you might need to adjust your clutch pedal once your done. I am going to have to do mine in the next few days. Tere is a DIY video on here. someplace.
95SL_2501 is offline   Reply With Quote Quick reply to this message
Old 02-15-2010, 06:41 PM   #6 (permalink)
Yes, I beleive your right.
Yep, I filled up the resovior and it all puked out unto the concrete, down next to the tranny
Yea, at the rate of my failure at achieving the greater things in life, looks like I'll be driving my baby another 14 years
Just got back from Tha Zone...picked up a unit made in Tiawan
I am going to atempt to do this myself tommorow.Off hand, do you know what tools I will need?
Also, this new Tiawan unit, it came with a brass rod about 2" long. On one end there is a groove. Which end of this rod goes into the slave cylinder and which end goes into the tranny
I sincerely appreciate the help I receive here @ 3si. I really do appreciate your help
Old 02-15-2010, 07:00 PM   #7 (permalink)
"Sore about slapdown"
jackhammer's Avatar
Drives: VFR800
jackhammer Level 2jackhammer Level 2jackhammer Level 2jackhammer Level 2jackhammer Level 2
Feedback Score: 88 reviews
Yep, the slave cylinder
Fairly easy to replace and bleed
jackhammer is offline   Reply With Quote Quick reply to this message
Old 02-15-2010, 07:43 PM   #8 (permalink)
Minnesota 3/S
Drives: 95 RT TT
No special tools at all i you will need is a flat head, a fourteen and twelve MM socket and a few extensions.
Take off the air filter, MAF, and intake pipe. Next remove the battery, battery tray, and washer fluid tank. You will see the slave sitting straight down from the throttle body after you remove the washer tank. couple of 12MM bolts and it will be out. now youre going to need someone to help you bleed the clutch though.
Old 02-15-2010, 08:01 PM   #9 (permalink)
Daaaamn, looks like we got some kinda epidemic going on around here
Jack, my Man. I was going to give you a shout-out if I didn't get any help with my thread. I didn't wanna waste your time if I could help it
BTW, For those who are not aware...Jackhammar is a freakin machine. He preformed a 60k service for me about 6 weeks ago(1,500miles) and my car hasn't ran this good since 1994
Jack, I may still give you a holler if thats cool. I wish you were here Bro
Old 02-15-2010, 08:26 PM   #10 (permalink)
jackhammer's Avatar
Drives: VFR800
Yea thats cool man, call me when you are getting around to it. Thanks for the props.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
