Old 10-07-2009, 02:07 PM   #1 (permalink)
I love lamp
tsmitty025's Avatar
Drives: '01 Oldsmobile Alero
tsmitty025 is an unknown quantity at this point
Default Clutch going at 58,3XX?
Yep, so I just got my car about 2 weeks ago (1991 Stealth ES) and the clutch started slipping today. The odometer reads 58,300 miles (the interior would match the mileage... perfect red leather, no stains on carpet, just immaculate) and I don't think it was tampered with. I haven't even done the 60,000 mile service yet and the clutch is already going? Is this the normal mileage for this drivetrain? I previously had a Focus and didn't have to worry about the clutch until 90,000 miles...
And on top of that question, what kind of clutch should I get? It's a DD and will be slightly modded. I did some research and am thinking Spec Stage 2 and a 9lb. Aluminum Fidanza Flywheel... I'm not sure on pricing though, if there's anything better for less $$$ please tell me!
tsmitty025 is offline   Reply With Quote
Old 10-07-2009, 02:37 PM   #2 (permalink)
Drunk as a lord
Forest Gump's Avatar
Drives: 1992 Stealth TT
Trader Rating: (59)
Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2
Default Re: Clutch going at 58,3XX?
low mileage on an old car can mean a lot of stop and go city driving which eats the clutch. Depending on how many owners your car had in the last 19 years or so there was probably someone along the way who abused the clutch or just didn't know how to drive.
I'd just get a stock replacement auto parts store clutch for a FWD unless you plan on drag racing it really hard or going turbo. I'd also just pickup an oem flywheel from autozone or get yours resurfaced.
Power:13Ts, 550s, AEM FPR, Emanage Blue, K&N, Downpipe, ATR Catback, DevilsOwn meth, UDP, SSQV, EVC5, Walbro, IK24s
Best 1/4 12.62 @ 111.9 2.0 60 FT Best 1/8th 8.00 @ 87.24 1.80 60FT
Suspension: Konig Villians, Pilot A/S, Tein S-Techs, Hawk HPS Pads, 2G brakes AWS Delete
Drivetrain: ACT HDMM, 300m O/S, PST 2 piece Al/Steel Driveshaft, F&R Poly Mounts, EK2 ExoCage
Etc: Leatherseats.com Charcoal/Grey Interior, 99 front end/lights/wing/sideskirts/doorcaps, Scanmaster3, AEM UEGO, 3sx single pass 2" radiator
Samco rad hoses, Smokin'vr4 sub box with 10" MTX sub, Pioneer Amp, JVC KD-ADV49
Ball bearing STS
Forest Gump is offline   Reply With Quote
Old 10-07-2009, 02:38 PM   #3 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (217)
#1 60K on a clutch is not bad. They can last longer, but 60K isn't too bad. It all depends on the driver/abuse.
#2 unless you are going to add LOTS more power over stock, I would stick with an OEM or stage 1 clutch. There is no reason to upgrade clutches on a stock car. Don't be one of those people that feel the need to say "I have a stageX clutch".
-Chris
91VR4-3.0L-Stock heads and Cams-811AWHP 747AWTQ Daily Driver 10.57@141mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
NG09 and NG10 Title Sponsor
3SX Performance
3SX Performance Service Email
Carolina 3S Forum
Old 10-07-2009, 02:41 PM   #4 (permalink)
Brapppp!!
Hard AttacK's Avatar
Drives: 95 3000GT SL
Hard AttacK is an unknown quantity at this point
^ Lul :]
95 panama green sl---Maximal performance single shot cat-back+test pipe,3SX lightweight aluminum crank pulley,plenum spacer, HID's 55w 12k Lows, 35w 4.3k highs, 35w 3k fogs, K&N drop in, South bend stage 1 clutch kit w/NAPA flywheel, 3sx long tubes coming soon, hello kitty oil cap Upgraded sound system, custom green dash lights
Originally Posted by Turbo Beast View Post
People who wear crocs out in the open need a good can-o-whoopass
Originally Posted by Import Power View Post
Ethanol only
Only I drive it (wife used to but now it scares her)
Her name is bitch
Hard AttacK is offline   Reply With Quote
Old 10-07-2009, 02:53 PM   #5 (permalink)
I love lamp
tsmitty025's Avatar
Alrighty then, thanks for the input.
