Old 05-01-2008, 07:55 PM   #1 (permalink)
jj2314 is an unknown quantity at this point
Default Changing the Transmission Fluid Need Some Help
Im in the process of putting new transmission fluid in my 3000gt.
However the filler bolt is stripped by the idiot that owned the car before me and i can not get it off.
Is there any other way to get the new transmission fluid in the car or any suggestions on how to get this bolt out?
Thanks
jj2314 is offline   Reply With Quote
Old 05-01-2008, 09:08 PM   #2 (permalink)
Drives: 94 3000gt base
Trader Rating: (15)
dhrubio is an unknown quantity at this point
Default Re: Changing the Transmission Fluid Need Some Help
Thanks
Click here, and go about halfway down the page. Under Post-Installation, go to step 6. Fluids and look at Morf's FWD note.
dhrubio is offline   Reply With Quote
Old 05-03-2008, 08:46 AM   #3 (permalink)
ok i have got the speedo cable off along with the 10mm bolt but am now stuck.Any suggestions on how to turn the piece and get it off because it is not budging.
Any help would be appeciated since i really need this done by this weekend
Old 05-11-2008, 05:43 PM   #4 (permalink)
Cant get there from here!
speedy25's Avatar
Drives: Various Japanese
Put the cable back on and use the cable nut to spin the sensor a little and probably to pull it out as well. These frequently get some corrosion above the o-ring and can be tough to get out.
-SP
One of 789
