Old 07-03-2009, 10:26 PM   #1 (permalink)
nystreetguru's Avatar
Drives: 1995 3000gt SL
nystreetguru Negative 3
Default Belt making occasional noise
Belt on the left side ( i know theres like 3 of them) of the engine bay making noise only when i bring her up. If i shut it off and let it sit for a while and drive it like i should i have no problems....the problem here is i dont want anything to get worn out ...which belt is most likely to go? My timing just got changed i know its not that...any help would be appreciated. 95 SL.
nystreetguru is offline   Reply With Quote
Old 07-07-2009, 02:08 PM   #2 (permalink)
94 3000gt dohc
j3000's Avatar
Drives: 1994 3000gt
j3000 is an unknown quantity at this point
Default Re: Belt making occasional noise
serpentine belt is most likely the problem. They tend to get worn out and make noises. This is the belt that is hooked up to your altenator. the other belt is a power steering belt i believe. Here you go this should help:
Stealth 316 - Alternator Drive Belt
Photobucket
j3000 is offline   Reply With Quote
Old 07-08-2009, 04:27 PM   #3 (permalink)
thanks j, i also found out that if i put on my A/C it squeals for a sec and stops...ive been driving the car daily and it hasnt done it sense....but i havent been beating the piss out of her either.
