Old 08-17-2009, 10:55 PM   #1 (permalink)
CarthageGT is an unknown quantity at this point
Default ATX to MTX conversion cost?
After some time thinking I realized that its not worth building up an atx trans ... a trans cooler, shift kit, and high stall torque converter would total up to around $1000. Even after all that I still would not be as fast as an mtx. A tt engine swap is also out of question its just too much of a hastle and the ripps supercharger is a p.o.s (I have a sohc btw).
What would it cost to convert an atx to a mtx???
CarthageGT is offline   Reply With Quote
Old 08-17-2009, 11:02 PM   #2 (permalink)
mikemet28's Avatar
mikemet28 is an unknown quantity at this point
Default Re: ATX to MTX conversion cost?
alot more than its worth doing, in money and labor
Photobucket
Photobucket
mikemet28 is offline   Reply With Quote
Old 08-17-2009, 11:13 PM   #3 (permalink)
mikemet28's Avatar
seriously though just a list of parts off the top of my head would be a manual trans, the whole clutch assembly, pressure plate, shifter cables, clutch master cylinder, lines, flywheel, tcu, and i know there are alot of other parts im leaving out.
Old 08-17-2009, 11:25 PM   #4 (permalink)
That is a lot but I'm certain that its been done before I just can't find any topics about it or the cost.
I would be able to get most of those parts (in decent to good condition) if I find a part out.
Old 08-17-2009, 11:39 PM   #5 (permalink)
mikemet28's Avatar
look for 5 speed conversions and manual transmission conversions you should find some good info
Old 08-18-2009, 12:07 AM   #6 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (143)
Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3
You need the shifter assembly, shifter cables, brake and clutch pedal assembly, slave cylinder, master cylinder, lines, starter, passenger axle, drivers side intermediate shaft, starter, flywheel, clutch kit and of course the trans.
Old 08-18-2009, 10:40 AM   #7 (permalink)
mikemet28's Avatar
howd i know you would know exactly what he needed
Old 08-18-2009, 11:16 AM   #8 (permalink)
Thats a lot of things but if I find a parts car with all of those things then I'd be in luck. You also said in this thread that a mtx swap would be better then building an atx.
Would you still recommend an mtx swap > building an atx?
93 3000gt sl V.S. 01 eclipse gt - Car Forums and Automotive Chat
Old 08-18-2009, 12:09 PM   #9 (permalink)
AWD rules
SLguy's Avatar
Drives: 94 black SLTT & VR4
Trader Rating: (22)
SLguy Level 2SLguy Level 2SLguy Level 2SLguy Level 2SLguy Level 2SLguy Level 2
why not do a TT conversion with 9b's @ 8 PSI (not engine swap but conversion) and just throw on a tranny cooler? You could do that for a grand and be way faster than an N/A MTX.
Black 94 SL Twin Turbo Automatic - 63K miles, < 1K on engine
purchased 3/2001, TT converted 6/2003
8.5:1 Arias Pistons, Pauter Rods, DR Stage 3 heads, 3sx td05 kit, EVOIII 16G's (currently set at 17 psi), PTC high-stall torque converter, shift kit, LSD, FMIC, 550cc injectors, walbro 255lph, 3SX single pass radiator, and supporting mods.
Black 94 VR-4 (The black wasp) - purchased 8/10/2009, 80K miles, R.I.P. 2/19/10
Air Intake, Blitz SBC-iD @ 14 psi, 50 lbs of wasp nests removed
2004 Jeep Grand Cherokee Special Edition - Daily Driver
SLguy is online now   Reply With Quote
Old 08-18-2009, 12:21 PM   #10 (permalink)
Damage Control
Stealthee's Avatar
Staying NA, yes. THe NA's just do not make enough power to compensate for the long gearing of the ATX trans.
