Old 07-18-2008, 11:04 PM   #1 (permalink)
Drives: Green '93 3000GT SL
Slainthrax is an unknown quantity at this point
Default 5th gear slipping out of gear?
Whenever im in 5th, and only 5th. If im on the gas, or decelerating its fine. I can accelerate fine. But 1/2 to 3/4 of the time when i get off the gas the shifter pops down and out of gear. I can prevent it from doing it by holding the shifter up when i have to let off the gas. It will occasionally grind coming out of gear.
When i drive. If i hit the gas the shifter will move in the 5th gear slot. forward and back.
What could this be?
Slainthrax is online now   Reply With Quote
Old 07-18-2008, 11:59 PM   #2 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (78)
Default Re: 5th gear slipping out of gear?
Stake nut is loose. Dont use 5th until you fix this. You will end up destroying 5th gear and possibly your entire trans.
There are instructions on how to fix it. Just have to search.
Old 07-19-2008, 09:06 AM   #3 (permalink)
I dont know if im mechanically capable of doing that. How hard/ expensive would it be for someone to do it for me at a shop.?
Old 07-19-2008, 09:20 AM   #4 (permalink)
Damage Control
Stealthee's Avatar
Trader Rating: (78)
Its actually verfy easy if you have the tools. I wouldnt waste my money taking it to a shop.
Old 07-19-2008, 09:28 AM   #5 (permalink)
whmdan is an unknown quantity at this point
I pretty much have the same thing, very seldomly (like 1/50) happen to me in Reverse, should I also stop using reverse until I fix it?
whmdan is offline   Reply With Quote
Old 07-19-2008, 09:29 AM   #6 (permalink)
Damage Control
Stealthee's Avatar
Trader Rating: (78)
No. Reverse love to be tricky on these cars. Besides reverse isnt driven in for miles and miles so it wont destroy things like a loose stake nut on 5th will.
Old 07-19-2008, 09:50 AM   #7 (permalink)
Stealthee I searched and couldnt find any good how-too's. do you know where any are? And how long would this take to do?
Old 07-19-2008, 10:59 AM   #8 (permalink)
chevelle5434's Avatar
Drives: 1995 3000gt SL
chevelle5434 is an unknown quantity at this point
Pull the passenger wheel pull the pastic cover off that covers the trans. Drain the trans. unbolt the end cap on the trans, have someone hold the brake while the cars in gear and tighten the shank nut. VERY simple just did it on my buddys NA last weekend.
Just to let you know you dont have to pull the trans this is just a picture I have layin around.
Photobucket
chevelle5434 is online now   Reply With Quote
Old 07-22-2008, 12:37 AM   #9 (permalink)
x2percentmilk's Avatar
Drives: 93 3000gt
x2percentmilk is an unknown quantity at this point
Yeah def. dont use 5th until you fix it. I did and i ripped my transmission wide open (not exaggerating)
Its an easy fix, really easy. Ive never worked on a car in my life and pulled the tranny (had to at the time, you probably wont need to) replaced all of the broken internal and external parts, and put it back in running fine.
BM Tranny LSD Insert Installation
gives great info / pics on how to open up the end cap, or the entire thing if you ever need to.
x2percentmilk is offline   Reply With Quote
Old 07-23-2008, 10:20 PM   #10 (permalink)
It should be in 5th gear to tighten correct?
