Old 01-14-2008, 05:54 AM   #1 (permalink)
DR650R-Powered; IPS-Built
VirginiaTechVR4's Avatar
Drives: '95 Mariana Blue VR4
VirginiaTechVR4 is an unknown quantity at this point
Default Wierd noise after launch... help diagnose
Ok, so here is the story...
New clutch, SPEC Stage 3+, just put 750 miles on it, of which 650 were city driving... so I wanted to try a launch.. nothing crazy, just a 4K drop...
So rev up to 4k, drop the clutch, front wheels spin for a sec, just a chirp, and car takes off, and bogs... so i put the clutch in, and stop, and try again...
2nd try i ease the clutch out a little more, sort of bogs, but grabs and goes, so do a 1-2-3 shift and head home..., everything seems fine
When I get to my apartment complex and make a few stops i realized there is a grinding noise in 1st gear, def in sinc with the wheel rpm, not so much engine rpm...
I can hear it sometimes in 1st gear accel, but sometimes not... but I hear it everytime in 1st gear decel, with the accelerator in just a little or out. If engine revs are coming down, the noise is present in 1st gear. I thought i heard it once in 2nd gear, but I have not been able to get it to do it again.
The noise is best described as a whine, or metal grind with a frequency tied to wheel (driveline) rpm.
Any ideas as to what could have happened??? Car shifts/runs smooth, just this noise when i happen to be in 1st decel.
I have a gmeter in the in the car, so when it stops snowing im going to go out and do a 1-2-3 run and log power, if its under 150 I will know im in FWD and fried the VCU, though I don't think this would have happened. I also need to see if the noise goes away when I put the clutch in, I think it does, but need to verify. Could it be the clutch?
Thanks,
Tony
1995 Mariana Blue Pearl 3000GT VR-4
NG '08 - 1st Place Best 2nd Gen, 1st Place Best Exterior, 1st Place Best Interior
Nov. '06 - Ride of the Month
Quote from some guy: "What kind of car is this?", Me: "Mitsubishi", guy: "Brand New huh?", Me: with a big ass grin "um, its a 95."
Previous Member: llushman --> 3SI Member Since Feb 2004 --> 3S Owner Since August 2002
Proud Customer of IPS Motorsports
1995 3000GT SL - Supercharged - R.I.P - Dec. 2003
VirginiaTechVR4 is offline   Reply With Quote
Old 01-15-2008, 03:56 PM   #2 (permalink)
Never finished
1viciousVR4's Avatar
Drives: Nowhere Fast
Trader Rating: (28)
1viciousVR4 is an unknown quantity at this point
Default Re: Wierd noise after launch... help diagnose
mine does that also in 1st gear, no other gears, never paid attention to it, it sounds like im driving in reverse just not nearly as loud, but that kind of whine.
99 Chevy Silverado 2500
93 3000GT VR4
So far: 3sx TD05 E16g Turbo Kit, polished Greddy FMIC with IPS tdo5 extensions, AEM EMS, PTE 680cc, Poopra pump, 3sx pulley, MSD wires, NGK coppers, Maximal powdercoated valve covers, polished plenum, Tial Q bov, Hallman Pro RX MBC, Maximal solid mounts, Maximal test pipe, JIC catback, Tein s-techs, Mod-Express 8k HID, Nelson TC bracket, Fidanza flywheel, RPS Max street, Deft CF hood.
1viciousVR4 is offline   Reply With Quote
Old 01-15-2008, 04:41 PM   #3 (permalink)
yea, its a similar whine, but i think on mine its more of a grind... Hopefully I will have time this weekend to do some troubleshooting and update this thread so i can figure this out...
Old 01-15-2008, 04:43 PM   #4 (permalink)
SirLaughaloTT's Avatar
SirLaughaloTT is an unknown quantity at this point
Could possibly be the throw out bearing.....oooor it could be a shard of metal winding through first gear ripping up lol probably not tho.....
Turbo in the blood
In Loving memory of Richie Bonini It won't be long will meet again
Tdo5 headers, evo III 16g's, manual boost controller, denso full pump hotwired, egr delete, soild motor mounts, 680 injects,godspeed front mount intercooler 24x12x4 with ppe piping. aeromotive Fuel pressure regulater, sx fuel filter steel braided lines, greddy ultimate,lc-1 wideband AC delete, cruise control delete..I think thats all
SirLaughaloTT is offline   Reply With Quote
Old 01-17-2008, 04:49 PM   #5 (permalink)
KORMEX's Avatar
Trader Rating: (11)
KORMEX Level 3KORMEX Level 3KORMEX Level 3KORMEX Level 3
Thanks,
Tony
The gmeter thing doesn't make alot of sense to me , maybe i'm not following you .
BTW its almost imposible to describe a sound through text
KORMEX is offline   Reply With Quote
Old 01-17-2008, 06:26 PM   #6 (permalink)
Agreed. noise and text just dont go hand in hand... but its prob. too faint to pick up with a camera...
On the gmeter, it knows the weight of the car, and somehow it calculates acceleration (not sure how) and can display horsepower. If its in FWD I would think the car would accelerate less quickly, therefore the gmeter would pick up less horsepower (based strictly off acceleration, i know the car is still make XX HP). At least in theory this sounded like it could be a way to tell.
All in all, its just a noise... maybe I'll just drive it till it breaks, who knows... how often is anyone in 1st gear decel anyways.
Ill try a couple more things over the frigid weekend and maybe some local 3S guys can come over and listen in.
Old 01-18-2008, 05:48 AM   #7 (permalink)
KORMEX's Avatar
Trader Rating: (11)
Having a blown VCU would make your car act like it has an "open" ctr dieeferential and not like its FWD . The gMeter has a small accelerometer to measure acceleration but it doesn't know anything about traction and other variables.
To troubleshoot your noise you need to get your car on a lift and listen from underneath
Old 06-17-2008, 08:58 AM   #8 (permalink)
banktech78's Avatar
Drives: '92 RT/TT, '95 SL
banktech78 is an unknown quantity at this point
Did you ever determine what the issue was? Mine has that problem too from time to time and only in 1st gear....Weird.
banktech78 is offline   Reply With Quote
Old 06-17-2008, 09:08 AM   #9 (permalink)
973KGT's Avatar
Drives: 1997 3000GT VR4
973KGT Level 5973KGT Level 5973KGT Level 5973KGT Level 5973KGT Level 5973KGT Level 5
Personally I would never use first gear in the 6-speed to decel. It's to short and by the time your going slow enough to safely put it in 1st gear your almost at a stop anyway.
The way your launching is taking a toll on your entire drivetrain by the way. When you launch these cars or any AWD really, it is always good practice NOT to drop the clutch. You need to rev to about 5-6K then slip the clutch out until the drivetrain in loaded up. Once you get to that point you can release the clutch and go. This will also solve the "bogging" issue which is caused from you building boost in the very begining but loosing that boost through the part of first gear because the rpms drop below boost. When you slip the clutch you keep the rpms up and therefore boost.
The 'mod bug' is like herpes - even if you get it under control, it's only a matter of time before it comes back to remind you it's still there
I tend to judge people on their use of the English language
973KGT is offline   Reply With Quote
Old 06-17-2008, 09:51 AM   #10 (permalink)
Gear Head
Bret Brinkmann's Avatar
Drives: Rear wheels only...
Bret Brinkmann Level 4Bret Brinkmann Level 4Bret Brinkmann Level 4Bret Brinkmann Level 4Bret Brinkmann Level 4
Clutch noises are associated with engine speed not vehicle speed. If your VCU popped, then you would spin the front tires pretty good not just chirp them. I agree with 973KGT, your launch technique is too abusive. Dumping clutches especially above 5K rpms breaks stuff and is unnessisary for most cars. Try releaseing it "relitively" slow at first untill you can feel it start to grab, then let it out the rest of the way as fast as you can. It will take some practice, but the lower you can get your rpms on a launch the better you will be. Start off with lower rpms and work your way higher. Breaking is more embaresing than loseing. And costly. If you absolutely can not launch the car lower than 5K, then it is time for bell housing reinforcement.
As for your concern, the first question that comes to my mind, is what gear oil you are using? has the tranny been taken appart resently?
250 RWHP
