Old 06-09-2006, 05:17 PM   #1 (permalink)
mightymoose's Avatar
Trader Rating: (20)
mightymoose is an unknown quantity at this point
Default what could cause a 25 spline whirrling noise followed by extreme heat..?
Any advice is appreciated on this one.. I have a 25 spline tranny on my 92 VR4 after about 400+ miles of driving on a 40k miles tranny, never launched, not driven hard; only seen 14psi, rps FW and 6-puck, used only redline fluids.
axles with about 8k miles on them,
Began to notice a whirrling noise, actually sounded like a bearing noise or a small exhaust leak..(checked for that as well--wasn't it) I've checked everything axles, mounts, everything on suspension, exhaust is new. new CF driveshaft, new TOB, slave cylinder, etc. new axle seals, etc, input, output bearings.
Noise begins around 2500k rpms and is in everygear including neutral,, Reverse is the worst. when one hits the gas,, very noticeable, and when rpms drop,, it is followed by a small "clunking" sound. Also the tranny gets extremely hot.. you can touch it and it feels like touching and exhaust manifold.
Plenty of fluid in it,, flywheel/clutch looks ok. it shifts fine, no power loss and clueless as to what it could be?? Bearing failure?
Any thoughts are greatly appreciated.
Thanks
James G
99 & 92 VR4
mightymoose is offline   Reply With Quote
Old 06-10-2006, 11:32 AM   #2 (permalink)
Trader Rating: (20)
Default Re: what could cause a 25 spline whirrling noise followed by extreme heat..?
Anyone??
James G
99 & 92 VR4
Old 06-10-2006, 12:20 PM   #3 (permalink)
Markieb124's Avatar
Drives: 93 RT/TT
Trader Rating: (54)
Markieb124 is an unknown quantity at this point
i would pull the drain plug and see if things are getting shaved off. check to see the tranny fluids condtion
1993 stealth r/t TT
lots of go fast goodies.
Visit my CarDomain and tell me what you think. Let me know your from 3SI
www.cardomain.com/id/markieb124
Markieb124 is offline   Reply With Quote
Old 06-10-2006, 02:32 PM   #4 (permalink)
Trader Rating: (20)
Did all thay,, the fluid levels and the fluid itself looks ok..
