Old 07-06-2008, 12:31 PM   #1 (permalink)
AxeMan's Avatar
AxeMan is an unknown quantity at this point
Question VR4 Shifter Problems
I have a 92 VR4 the shifter is very notchy/resistance in every gear.
Not so when the car is not moving and you shift through the gears.
I put in the under hood bushings but still no improvement.
Is the problem in my shifter,the linkage itself ?
Will a short throw solve the problem ?
Any help would be greatly appreciated !
Thanks
AxeMan is offline   Reply With Quote
Old 07-06-2008, 01:04 PM   #2 (permalink)
Kibwe Walker's Avatar
Drives: 93 RT/tt
Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7
Default Re: VR4 Shifter Problems
Try adjusting you clutch pedal underneath the dash.
Do a advanced search on Clutch Pedal Adjustment and you will come across threads with pics and procedure.
Other than that I would look at the hydrolics (slave and master cylinder).
His - Red 93 RT/tt
Mods: Hallman's MBC @ 16 psi, turbo XS type H BOV, stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, slightly gutted mas, dsm SMIC's, ACPT 1 piece CFDS, Tein S springs, pte 580 inj's, safc neo/SITC, 13t's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer.
Hers - BPU Green 94 vr4
Kibwe Walker is offline   Reply With Quote
Old 07-24-2008, 07:29 PM   #3 (permalink)
petty is an unknown quantity at this point
It sounds like the problem in the shifter itself or the shift rails inside the box. Try first messing with the shifter but I think that the rail or syncr may be the real problem.
___________________________
Autopartswarehouse Auto Modifications.
petty is offline   Reply With Quote
Old 07-25-2008, 08:52 AM   #4 (permalink)
High on Speed
Jake91Vr4's Avatar
Drives: 91 VR-4
Trader Rating: (7)
Jake91Vr4 is an unknown quantity at this point
sounds like synchro's
'91 VR4 : Mods:
to move: ATR downpipe/turbo back exhaust, Denso fuel pump, PTE 550cc injectors, 15g turbos, Stillen intake, greddy BOV, New throttle body/plenum,
to Monitor: MBC, AFCII, Dual turbo timer, A/F, and dual pillar pod with Boost and Pyrometer gauges
to Stop: cross drilled rotors
Interior: all audiobahn speakers, 10" Audiobahn w/ custom box
Planning: Seats, rims, and any other un expected part that breaks
Jake91Vr4 is offline   Reply With Quote
Old 07-25-2008, 09:01 AM   #5 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (66)
Put the car in 1st, with the clutch IN. Rev. Do you move forward?
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
