Old 04-09-2008, 05:03 PM   #1 (permalink)
My92Stealth's Avatar
Drives: 91RT/TT,92Base
Trader Rating: (34)
My92Stealth Level 1My92Stealth Level 1
Default Transmission woes...
I swapped a 25 spline transmission and transfer case into my 91 TT, which had with 18 spline to begin with, and I am having some troubles.
When I drive straight forward or back, everything is fine. But when I turn any amount in any direction, the car stutters and binds. It feels like something is binding up.
I dropped the transmission and the front diff. is in great shape. No missing teeth, no chunks taken out, spins fine, etc.
Prior to this I thought it may be a bad axle (the boot on the pass. side was torn and the car had been sitting for a few months) so I replaced it, but that did not solve the problem. I checked the drivers side axle and mid-shaft and both spin freely and seem to be fine.
Any ideas what might be wrong? Cars been down for about 6 months :\
1991 RT/TT Pearl White/Porn Red 15g's + supporting, other mods. 92 Stealth Base DD.
My92Stealth is online now   Reply With Quote
Old 04-10-2008, 11:43 AM   #2 (permalink)
Drives: 93stealth-91vr4
93stealthman is an unknown quantity at this point
Default Re: Transmission woes...
if your cv's are fine and your confident with your work. it might be a cracked diff. housing. have you had the 25 spline trans apart?
93stealthman is offline   Reply With Quote
Old 04-10-2008, 12:33 PM   #3 (permalink)
Trader Rating: (34)
Just took it all apart today.
VCU housing is cracked and the planetary gear assembly is in several chunks. Pics tonight.
Old 04-10-2008, 01:33 PM   #4 (permalink)
wow, carnage
