Old 03-24-2008, 11:10 PM   #1 (permalink)
Black Beast Rebuild 93%
TT4ME's Avatar
Drives: 94 TT, 92 ES, 92 TT
Trader Rating: (8)
TT4ME is an unknown quantity at this point
Default Transmission Replacement: Simple Question (I hope)
I have mainly been following the steps listed here : http://www.stealth316.com/2-trany.htm
I am currently stuck on getting the half shafts out. I have them out of the hub/rotor assy. and can't seem to get them out of the tranny. Directions say pass. side has a C clip and I'm not sure how to remove this.... Drivers side doesn't seem to want to break free either. I have never worked on a FWD tranny before... my helper has but it was an old civic and he said they just pulled out.
This is on my 92 TT if there is any difference.
Any tips from the pros? Thanks in advance.
Lightly modded 94 TT- $7500 ..... (perfect) 92 ES- $5500 ..... 92 TT- Not for sale
***Please stay away from Cascio420/Spacarelv/5fthot (eBay Ids)***
TT4ME is offline   Reply With Quote
Old 03-24-2008, 11:24 PM   #2 (permalink)
i can make your vtech cry
turbosprentice's Avatar
Drives: '96 3000gt(base)
turbosprentice is an unknown quantity at this point
Default Re: Transmission Replacement: Simple Question (I hope)
you mention about a fwd 3s. but you're working on a 92 TT? I thought TT means they're awd stealth? either way. they are a bit to remove, after you remove the clips, it takes a bit of pulling, i don't remember how many bolts i took out around that area but, when i did mine(base 3kgt) it took a while to pull them out, or more like yank them out. lol. I didn't seem to break anything. so i guess that worked.
turbosprentice is offline   Reply With Quote
Old 03-24-2008, 11:29 PM   #3 (permalink)
TT4ME's Avatar
Trader Rating: (8)
Sorry, by FWD I meant AWD.... I only have experience on RWD trucks. They are much easier to work on!!
So, how are the clips removed?? I have the car up high on jackstands and haven't been able to see such clips.
Old 03-25-2008, 05:11 AM   #4 (permalink)
jefhaz is an unknown quantity at this point
The c clip is on the end of the staft inside the transmission. It compresses and locks the axle in place. Use a big screwdriver to apply some pressure and pop the axle out. Be careful with the seals.
jefhaz is offline   Reply With Quote
Old 03-25-2008, 05:13 AM   #5 (permalink)
Drives: An AEM car in -10F
Trader Rating: (9)
MustGoFaster is an unknown quantity at this point
Passenger side: Prybar between the axle and tranny. Pry and it will pop out.
Driver side: Un bolt the carier bearing (2 14MM bolts) and remove, no prying required.
~Ryan
92 Stealth R/T TT- Not exactly done
93 Stealth R/T TT- I might make it run eventually
MustGoFaster is offline   Reply With Quote
Old 03-25-2008, 11:18 AM   #6 (permalink)
TT4ME's Avatar
Trader Rating: (8)
Thanks, I forgot about those 2 bolts. Rd 2 of my tranny replacement starts soon!
Old 03-25-2008, 05:38 PM   #7 (permalink)
phantomrt's Avatar
Drives: fast
phantomrt is an unknown quantity at this point
Those "C" clips can be a bit of a pain sometimes... equal prying on opposite sides of the CV axle is key.
So, how do you get the front wheel bearings out of the hubs of a late model 4x4 3/4 ton Dodge? I'll pull my engine/trans out of my Stealth again before I do another one of those.
92 Stealth R/T TT 70k
92 Daytona ES 2.5 Turbo / A523 103k
92 Lebaron GTC Conv. 2.5 Turbo / A568 153k
91 Daytona ES 3.0 V-6 / A543 190k
95 Grand Prix SE 3.1 / 4T60E 202k
phantomrt is offline   Reply With Quote
Old 03-25-2008, 10:33 PM   #8 (permalink)
TT4ME's Avatar
Trader Rating: (8)
Ok after furthur inspection I've located the 2 14mm bolts. Next question is how in the F$#@ can you get those bastards out. There doesn't seem to be any room to get to them from below and from the drivers side wheel well I don't seem to have a combination of wratchets to loosen even the bottom nut. (top looks to be twice as hard to get to)
Any secrets?
I know these cars are tight but what I'm looking at is rediculous.
phantomrt: I've never messed with wheel bearings before. Just tranny replacement on RWD trucks. GL
Old 03-26-2008, 10:33 AM   #9 (permalink)
Breaks all but Xfer case
flyman1981's Avatar
Drives: 04 325xi, 93 VR-4
Trader Rating: (6)
flyman1981 is an unknown quantity at this point
THey come out with just enough room. I think i stick my arm up through the wheel well area and use my other from behind to hold the ratchet on the bolt.
Dont mix up those two bolts with the others, they are a different thread pitch.
Black 93 VR-4
12.60 @ 108 w/ 9b's, 550's BlowThrough MAFT and E-Manage
11.77 @ 123 w/ 14b's (22psi), FMIC, MAFTPRO, 650's
??.?? @ ??? w/ 14b's (26psi)
??.?? @ ??? w/ 14b's (24psi) + NOS (35shot)
Show and Go:
HKS cat back, 98 rear garnish, EGR block off plates, Phantom boost guage, Walpro 255 lph, Intrax, JayVR4 control arms, 1-4 Syncros, Kormex output shaft, RPS MAX Street Disc, Resurfaced Flywheel, ATR Downpipe, HKS SQV, Dejon dual intakes, AEM Wideband, mobo shift/ebrake boots, Battery Relocation, MAFT PRO, 14B Turbos, DNP TDO5 Headers, Tial Wastegates, DNP FMIC, P+P Heads, 99 Lifters, Vac Reduction, 98 Body kit, 94 Robot headlights, Ross Pistons, Balanced Crank, Denso 650, IPO FPR w/ Gauge, Flexalite fans, Boost a Pump, ARP Head Studs, CF 575 Hood, 50HP NX Wet Kit, NOCAR Xfer Case, Veilside CF spoiler, ACPT CFDS, 19x9 SSR D5R, Blitz SBC-ID, Boomslang harness, Corbeau LG1's
flyman1981 is offline   Reply With Quote
