Old 03-12-2007, 06:05 PM   #1 (permalink)
Meow
eblank8's Avatar
Drives: Red 91 3000GT VR4
Trader Rating: (20)
eblank8 is an unknown quantity at this point
Default Transmission leak found... hopefully
So I took my car apart today to try and source down a transmission
leak. Well, i think i found it. My transmission would only leak while I
was driving and for 1-2 days after it would dump all over the driveway.
Then nothing would drip unless I drove the car again. So I looked my
car over and it seems to be coming from my passenger side axle. I
Remeber the seal was broken a little when I got the transmission from
someone trying to pry the axle out of it. I put some sealant on it and
hoped it would hold. Well, my transmission help fluid fine for about 4
months. Then it got horrid. I assume that tons of fluid would be flung
all over the underbody of my car and then for the next day or two it
would drip off the car until I drove it again. Then the process would
start again. Does this sound like it could be the cause for it all? Now
how would I go about fixing this? Can I do it with the trans in the
car? What seal kit do I need?
5Zigen FN01R-C BLP w/ 265/35/18 Nitto 555's
JDM (MR) Geared 6-Speed Swap w/ PST CFDS
Full 99 Body Conversion w/ DeftRacing 575 Hood
eblank8 is offline   Reply With Quote
Old 03-12-2007, 06:27 PM   #2 (permalink)
Dont Make Me Lose My Mind
Dakken's Avatar
Drives: 92 Stealth RT TT
Dakken Level 7Dakken Level 7Dakken Level 7Dakken Level 7Dakken Level 7Dakken Level 7Dakken Level 7
Default Re: Transmission leak found... hopefully
That axle seal is pressed in. I pressed mine in myself but I had the whole transmission apart when I did it. I think you could do it with it still on the car by prying the old one out and gently tapping the new one in with a big socket and hammer. I am not sure on that so get someone else's opinion on that.
You can get the seal here as part of a kit. I'm not sure if they would sell it individually so you would have to contact them.
http://supercar-engineering.com/sc2/...be682217ba4bd0
Dakken is offline   Reply With Quote
Old 03-12-2007, 06:48 PM   #3 (permalink)
Meow
eblank8's Avatar
Trader Rating: (20)
the only part that was ripped was a small part on the outside of the transmission... I am wondering if this is the culpret now after seeing the pic of the seal.
Old 03-12-2007, 07:52 PM   #4 (permalink)
Dakken's Avatar
It doesn't take much of a tear on the rubber to leak oil. That is the only seal on the drive axles that keep the oil in the transmission. Even a small tear will make it leak. You just have to be careful when you first insert the axle so you don't jack up the seal.
Old 03-13-2007, 08:15 AM   #5 (permalink)
*GT
One Shizz-rippin' M F
*GT's Avatar
Drives: Daihatsu
Trader Rating: (43)
*GT is an unknown quantity at this point
its easy once you pull the axle off, just pry it out with a screwdriver/prybar, and press the new one in with an appropriatly sized socket or pipe. You just need to make sure its in straight or it will leak again.
Black 92RTTT
EVO 3 16g's with JAC headers, 6 speed, 5zigen FNO1c's, AN-6 fuel lines and Aeromotive FPR, PTE 680's, 13.5"AP 6pot brakes, AEM EMS, DSM sidemounts, useless stuff removed.
60k's done $300+ parts, can do any 3/S work.
Parts for sale: http://www.3si.org/forum/showthread.php?p=3961260#post3961260
*GT is offline   Reply With Quote
Old 03-13-2007, 10:00 PM   #6 (permalink)
Meow
eblank8's Avatar
Trader Rating: (20)
I found a brand new seal just sitting in my garage! When my brother had a Vr4 he replaced the same seal, and apparently bought a few. I got the seal replaced, but my axle boot's clamp was missing... so that came apart. I dont know what happened, but I need this fixed now. We will see if this fixes it. I gotta cross my fingers, otherwise I am in for a ton more work and money.
Old 03-14-2007, 05:50 AM   #7 (permalink)
TEXAS!! FIGHT!!
AdamVR4's Avatar
Drives: NoCar XCase Test Car
Trader Rating: (22)
AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7
Heh, your brother decided to by multiples of a $25 seal? Nice
PEARL WHITE '93 VR-4 // Under Construction. Looking forward to lighting up the drag radials
E16G's: 10.573 @ 135.01
(Trevor owns me )
E16G's: 11.28 @ 124.7
(Pure pump gas ET record )
14B's: 11.10 @ 127.3
(AWD 14B ET record. Take THAT, Trev! )
9B's: 12.78 @ 107.1
Still clinging to my spot in the top 10:
DynamicRacing: US 3S Top 10 Fastest List
AdamVR4 is online now   Reply With Quote
Old 03-14-2007, 07:25 AM   #8 (permalink)
Dakken's Avatar
You will have to clean out the CV joint, regrease it and then put a new clamp on it. Some CV boots use zip ties to secure them so you can use a sip tie in a pinch. Otherwise, head to your nearest parts store for a new clamp.
Old 03-14-2007, 08:53 AM   #9 (permalink)
uhhh....Bankai?
Cecropia's Avatar
Drives: 91 RT TT
Trader Rating: (9)
Cecropia is an unknown quantity at this point
Lucky bastard
TN3S.......just say NO to 3.5Ls
Cecropia is offline   Reply With Quote
Old 03-14-2007, 09:31 AM   #10 (permalink)
Meow
eblank8's Avatar
Trader Rating: (20)
Yea, thats what I am planning. I am not in a pinch so I will do it right. I have an ample amount of time to finish. Luckily the boot didnt come off while I was driving anywhere. Since it only popped off while I was tearing the car apart, non of the dirt was mixed in and ground up into the axle joint. The axle was replaced less than a year ago. I cant believe that clamp only held for that long. Im going to have to take a look at my driver's side boot now. I bought them both at the same time. I threw out my receipt because it only had a one year warrantee, and i never thought I could use it!
